ActivePresenter Saola Animate Pricing Download
How to create a customized Fullscreen Button?
#1
Good Morning everybody,
Is it possible to define a “On Click” action to display the project in Fullscreen Mode? In “Adjust Variable” I cannot find those commands, neither anywhere in the Software Manual. Maybe there exist any useful JavaScript Code which I could use.
Alternatively it would be helpful to hide the progress bar in the Toolbar and to use only the “Display Mode Button”. But i would prefer a customized button, because i dont want to use the toolbar.
Background: We are currently investigating how to embed a project in a website with a header, navigation etc. The project size is to small in this case.
Many thanks in advance.
BR
Marcel
#2
Hasn’t anybody any idea?
Meanwhile I solved it with a workaround. A link on the project view opens a new browser window without any header etc.
(Dao Viet Phuong) #3
It requires coding in JavaScript. Basically, you need to add an On Click event to the button, and add an Execute JavaScript action with following code:
var containerElement = prez.container;
if (containerElement.requestFullscreen) {
    containerElement.requestFullscreen();
} else if (containerElement.mozRequestFullScreen) {
    containerElement.mozRequestFullScreen();
} else if (containerElement.webkitRequestFullscreen) {
    containerElement.webkitRequestFullscreen(Element.ALLOW_KEYBOARD_INPUT);
} else if (containerElement.msRequestFullscreen) {
    containerElement.msRequestFullscreen();
Wow, thanks a lot. That is exactly what i was looking for.
Learning never stops :slight_smile:.
(Alexandre Alves) #5
Hi Dao Viet Phuong!
Your Java Script code for FullScreen is very useful! But a question: How to toggle for non fullscreen in same button? Thanks!!!
(Toan Le) #6
Hi Alexandre,
For latest ActivePresenter version (7.5.2), you can use the following script to toggle fullscreen:
var fsAPI = AP.fullscreen;
if (fsAPI.fullscreenElement())
  fsAPI.exitFullscreen();
else
  fsAPI.requestFullscreen(prez.container);
(Alexandre Alves) #7
Hi Toan!
Sorry, But I do not have much experience with codes. How could I use this on a button? Thanks for advance
(Toan Le) #8
Hi Alexandre,
You can follow @phuongdv’s answer, just replace the code in Execute JavaScript action by this new code.
(Alexandre Alves) #9
Thanks Toan!
I was able to use this function. I hope it helps others!
best regards,
fullscreen.approj (200 KB)
