Problem: I found error notification when opening Active Presenter. It told me that Active presenter Failed to initialize multimedia library. Audio/Video related features will not function properly. So, I can’t record video with sound. Even in edit page, I didn’t hear any sound…
ActivePresenter Version: 8.1.0 - 64-bit build. (Released: 2020.04.10)
OS: Windows 10
HaiYen_Vu
(Hai Yen Vu )
May 25, 2020, 3:20am
#2
Could you please check the Sound icon at the bottom right of the Windows taskbar to see if it is enabled or not?
Some computers may need speakers or headphones plugged in to make it available.
Yen
drsnghnp
(Deepak)
July 10, 2020, 8:10am
#3
I am the same problem.
reinstalled the program. same problem. audio works fine with other applications
HaiYen_Vu
(Hai Yen Vu )
July 10, 2020, 8:50am
#4
Hi Deepak,
Have you tried the way mentioned above?
Besides, you can take a look at this similar thread to see if it helps:
Problem: Error on startup
failed to initialize multimedia library
7.3.2
OS:
W10 64b
Seems to related to recent W10 updates
log below:
2018-08-30 15:50:43: ActivePresenter 7.3.2 (Release Build: 2018.08.03) started
OS: Windows 10 (build 17134), 64-bit edition. Version: 10.0 - 64 bit
CPU Count: 6
Hostname: Russ-T3500. Memory: 12,285 MB. Available: 8,303 MB. Memory Load: 32%
Project Location: C:\Users\Russ\Documents\Activ…
Yen
PROBLEM SOLVED!
Good day. I’m having trouble with ActivePresenter 8.3.2 that the Multimedia Library can’t be initialized.
What I have done so far
Uninstalled, Reinstalled the latest Audio Driver for Lenovo S145 Laptop (Restarted in between operations)
Realtek Audio Driver for Windows 10 (64-bit) - S145-15AST, S145-14AST - Lenovo Support PH
Uninstalled, restarted laptop and reinstalled ActivePresenter 8.3.2 and activated my license
Audio is working on the laptop but still I have this error when starting ActivePresenter
Installing to a different computer: Working and can’t replicate the issue.
Remove all audio drivers except for the latest sound card driver: This solved the problem.
Shutdown the computer to confirm if the solution still worked. Problem solved.
Thank you.
Have a great day and keep safe always.
