Program crashes while starting up. Reboot laptop and attempt to start program, same results. Crashes for version 8.1.1 and 8.2.0
2020-09-18 06:52:14: ActivePresenter 8.1.1 - 64-bit build. (Release Build: 2020.07.24) started
OS: Windows 10 (build 18363), 64-bit edition
CPU Count: 8
Hostname: computernamehere. Memory: 16,190 MB. Available: 9,870 MB. Memory Load: 39%
Disk Space: 243,218 MB (Free: 25,936 MB)
Project Location: C:\Users\first.last\Documents\ActivePresenter
2020-09-18 06:52:14: TempDir: C:\Users\first.last\AppData\Roaming\ActivePresenter\temp
2020-09-18 06:52:14: Direct3D rendering mode: hardware
2020-09-18 06:52:14: Direct3D device type: 1
2020-09-18 06:52:16: Error while adding device to list: Windows WASAPI:Microphone Array (Intel® Smart Sound Technology (Intel® SST)): Invalid device
2020-09-18 07:07:49: ActivePresenter 8.2.0 - 64-bit build. (Release Build: 2020.09.14) started
CPU Count: 8
Hostname: computernamehere. Memory: 16,190 MB. Available: 9,001 MB. Memory Load: 44%
Disk Space: 243,218 MB (Free: 25,923 MB)
2020-09-18 07:07:49: TempDir: C:\Users\first.last\AppData\Roaming\ActivePresenter\temp
2020-09-18 07:07:49: Direct3D rendering mode: hardware
2020-09-18 07:07:49: Direct3D device type: 1
2020-09-18 07:07:50: Probing audio device for recording. Error: Invalid device. Retrying with default parameters
2020-09-18 07:07:51: Error while adding device to list: Windows WASAPI:Microphone Array (Intel® Smart Sound Technology (Intel® SST)): Invalid device
2020-09-18 07:07:52: Slide ID is duplicated in Project: C:\Users\first.last\Documents\ActivePresenter Templates\Default.apobject, Container: , Slide: Master Layout, Change the ID from 1 to 46.
2020-09-18 07:07:52: Slide ID is duplicated in Project: C:\Users\first.last\Documents\ActivePresenter Templates\Default.apobject, Container: , Slide: Title Slide, Change the ID from 2 to 47.
2020-09-18 07:07:52: Slide ID is duplicated in Project: C:\Users\first.last\Documents\ActivePresenter Templates\Default.apobject, Container: , Slide: Title and Content, Change the ID from 3 to 48.
2020-09-18 07:07:52: Slide ID is duplicated in Project: C:\Users\first.last\Documents\ActivePresenter Templates\Default.apobject, Container: , Slide: Two Content, Change the ID from 4 to 49.
2020-09-18 07:07:52: Slide ID is duplicated in Project: C:\Users\first.last\Documents\ActivePresenter Templates\Default.apobject, Container: , Slide: Question, Change the ID from 5 to 50.
2020-09-18 07:07:52: Slide ID is duplicated in Project: C:\Users\first.last\Documents\ActivePresenter Templates\Default.apobject, Container: , Slide: Question with Media, Change the ID from 6 to 51.
2020-09-18 07:07:52: Slide ID is duplicated in Project: C:\Users\first.last\Documents\ActivePresenter Templates\Default.apobject, Container: , Slide: Report Slide, Change the ID from 7 to 52.
2020-09-18 07:07:52: Slide ID is duplicated in Project: C:\Users\first.last\Documents\ActivePresenter Templates\Default.apobject, Container: , Slide: Title Only, Change the ID from 8 to 53.
2020-09-18 07:07:52: Slide ID is duplicated in Project: C:\Users\first.last\Documents\ActivePresenter Templates\Default.apobject, Container: , Slide: Blank, Change the ID from 9 to 54.
