Video lopp problem
I have a question. I have a project where I add a video, but it doesn’t loop continuously. For example, what do I need to do to make a 7-second video play repeatedly without stopping? Could you please provide detailed information?
Thank you for your question!
To make a video loop continuously in ActivePresenter, please ensure the following:
  • Enable the Loop option in the Properties → Media tab.
  • Make sure the slide duration is longer than the video duration.
  • Set the video to Play to the End of Slide (remove any exit effect if applied).
We’ve already provided detailed instructions with illustrations in a similar case here:
Please follow that guide step by step, and your video should loop correctly.
If you still encounter any issues, feel free to share your project file with us so we can take a closer look.
