Silent activation using rlactivator.exe does not work with -silent parameter (ActivePresenter 10)
Dear Atomi Systems team,
We are currently deploying ActivePresenter 10 in an enterprise environment using Liquit Application Workspace.
In the following forum post from 2018:
https://talk.atomisystems.com/t/license-not-working-today/555
it is mentioned that silent activation can be performed using:
rlactivator.exe -activate -pkey=<product_key> -silent
However, when we run:
rlactivator.exe -activate -pkey=XXXXX -silent
the activation does not complete silently.
If we remove the -silent parameter, the activation window opens and works correctly, but this requires user interaction.
Our goal is to:
  • Activate ActivePresenter automatically during deployment
  • Prevent the product key from being visible to end users
  • Perform activation fully unattended (silent)
Could you please confirm:
  1. Whether silent activation is officially supported in ActivePresenter 10?
  2. If additional parameters (such as activation method: direct/web) are required?
  3. If there is an alternative recommended method for enterprise/silent deployment?
We would appreciate clarification on the correct syntax or documentation for silent activation.
Kind regards,
Could you please let us know what error or behavior you are seeing when running the silent activation?
Also, please send the Activator log file of ActivePresenter to support@atomisystems.com for further checking. Kindly do not post it here, as it may contain license information.
You can find the log file at: %AppData%\ActivePresenter\
The log file name is: ActivePresenter.activator.log
Best regards,
