| cmi.completion_status |
incomplete |
| cmi.exit |
suspend |
cmi.interactions.0.correct_responses.0.pattern
180_13 |
cmi.interactions.0.id
180_2 |
cmi.interactions.0.learner_response
180_13 |
cmi.interactions.0.result
correct |
cmi.interactions.0.type
choice |
cmi.interactions.1.correct_responses.0.pattern
344_18[,]344_19[,]344_20[,]344_21[,]344_34 |
cmi.interactions.1.id
344_17 |
cmi.interactions.1.learner_response
cmi.interactions.1.result
correct |
cmi.interactions.1.type
sequencing |
cmi.interactions.2.correct_responses.0.pattern
345_4[.]345_5[,]345_6[.]345_7[,]345_8[.]345_9 |
cmi.interactions.2.id
345_1 |
cmi.interactions.2.learner_response
cmi.interactions.2.result
correct |
cmi.interactions.2.type
matching |
cmi.interactions.3.correct_responses.0.pattern
172_4 |
cmi.interactions.3.id
172_2 |
cmi.interactions.3.learner_response
172_4 |
cmi.interactions.3.result
correct |
cmi.interactions.3.type
choice |
cmi.interactions.4.correct_responses.0.pattern
179_4 |
cmi.interactions.4.id
179_2 |
cmi.interactions.4.learner_response
179_4 |
cmi.interactions.4.result
correct |
cmi.interactions.4.type
choice |
cmi.interactions.5.id
184_1 |
cmi.interactions.5.learner_response
184_1_1[.]investimenti[,]184_1_2[.]stabilire[,]184_1_3[.]standard |
cmi.interactions.5.result
correct |
cmi.interactions.5.type
performance |
cmi.interactions.6.correct_responses.0.pattern
182_4 |
cmi.interactions.6.id
182_2 |
cmi.interactions.6.learner_response
182_4 |
cmi.interactions.6.result
correct |
cmi.interactions.6.type
choice |
cmi.interactions.7.correct_responses.0.pattern
236_4 |
cmi.interactions.7.id
236_2 |
cmi.interactions.7.learner_response
236_4 |
cmi.interactions.7.result
correct |
cmi.interactions.7.type
choice |
cmi.interactions.8.correct_responses.0.pattern
346_4[.]346_5[,]346_6[.]346_7[,]346_8[.]346_9 |
cmi.interactions.8.id
346_1 |
cmi.interactions.8.learner_response
346_4[.]346_5[,]346_6[.]346_9[,]346_8[.]346_7 |
cmi.interactions.8.result
incorrect |
cmi.interactions.8.type
matching |
cmi.interactions.9.correct_responses.0.pattern
347_13 |
cmi.interactions.9.id
347_2 |
cmi.interactions.9.learner_response
347_13 |
cmi.interactions.9.result
correct |
cmi.interactions.9.type
choice |
cmi.suspend_data
{“info”:{“slides”:[{“1”:{“st”:2}},{“7”:{“st”:2}},{},{“12”:{“st”:2}},{},{“2”:{“s”:[1,0],“r”:2,“v”:[13],“p”:5,“a”:1}},{“17”:{“s”:[0,4,3,2,1],“r”:2,“v”:[18,19,20,21,34],“p”:5,“sp”:0,“a”:2}},{“1”:{“s”:[1,0,2],“r”:2,“v”:{“5”:[4],“7”:[6],“9”:[8]},“p”:5,“a”:1}},{“2”:{“r”:2,“v”:[4],“p”:5,“a”:1}},{“2”:{“r”:2,“v”:[4],“p”:5,“a”:1}},{},{“2”:{“st”:2}},{“2”:{“st”:2}},{},{},{“1”:{“r”:2,“v”:{“0”:“investimenti”,“1”:“stabilire”,“2”:“standard”},“p”:5,“sp”:0,“a”:3}},{“2”:{“r”:2,“v”:[4],“p”:5,“sp”:0,“a”:3}},{“2”:{“r”:2,“v”:[4],“p”:5,“sp”:0,“a”:2}},{“1”:{“s”:[1,2,0],“r”:3,“v”:{“5”:[4],“7”:[8],“9”:[6]},“p”:0,“sp”:0,“a”:3}},{“2”:{“r”:2,“v”:[13],“p”:5,“sp”:0,“a”:2}},{}],“fbs”:[],“randomMap”:{},“index”:20,“ts”:0,“elapsedTime”:214818,“vars”:{“apScoreSubtract”:0}},“map”:{“180_2”:0,“344_17”:1,“345_1”:2,“172_2”:3,“179_2”:4,“184_1”:5,“182_2”:6,“236_2”:7,“346_1”:8,“347_2”:9},“nextIdx”:10} |
