I am new to Saola and trying to preview my first publication. When I click on Preview Project in a Browser only the last scene appears. The first two scenes do not appear. The same thing happens if I publish to html5.
What am I doing wrong?
Hi Bob,
New scenes in Saola Animate are set to auto-advance by default and if there is nothing on the time-line, then it will simply skip through to the last scene.
Click on the scene and then in the properties panel on the right under scene, deselect the auto-advance option for each scene. You can also select multiple scenes and apply to all at once.
Thanks Mac. I did actually work it out after posting. Also mouse clicks don’t go through objects. Is there an overide?
Bobr
Do you want to click through transparent parts of objects? If so, please take a look at this thread: Events of transparent areas
