THANK YOU SO MUCH!! I got my files back and I will follow your instructions regarding crash dialog.
I got a crash dialog saying āActivePresenter is not respondingā while trying to import a video file to a blank project. Email ID: shahanajatik@gmail.com
Maybe the problem comes from your video. Can you please try using Handbrake to convert the video and import it again into ActivePresenter to see if it works?
Hang
Found 2 files in the path mentioned below. One is called Untitled and other is called Untiled -journal.
How do I recover my files from these. Please guide
(C:\Users<your_user_name>\Documents\ActivePresenter.ActivePresenterCachedProjects).
Log is as follows:
2021-01-19 09:20:13: ActivePresenter 7.5.13 (Release Build: 2020.03.03) started
OS: Windows 10 (build 15063), 64-bit edition. Version: 10.0 - 64 bit
CPU Count: 4
Hostname: LT1COGGG0516-47.technovaindia.cm. Memory: 3,996 MB. Available: 683 MB. Memory Load: 82%
Project Location: C:\Users\prigib\Documents\ActivePresenter
Disk Space: 156,372 MB (Free: 18,167 MB)
2021-01-19 09:20:13: TempDir: C:\Users\prigib\AppData\Roaming\ActivePresenter\temp
2021-01-19 09:20:25: PrepareRibbonBar: 6423ms
2021-01-19 09:20:44: flt sample format is not supported, s16 will be used
2021-01-19 09:20:44: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2021-01-19 09:20:44: Preparing to record audio from: Internal Microphone (Conexant ISST Audio). Channel: 2. Sample rate: 48000. Sample Format: 8
2021-01-19 09:20:48: Checking updates for ActivePresenter v7.5.13ā¦
2021-01-19 09:20:51: New updates available: 7.5.15
2021-01-19 09:20:54: Downloading updates to: C:\Users\prigib\AppData\Local\Temp\ActivePresenter_updater_tmp\ActivePresenter_v7.5.15_update.zip
2021-01-19 09:20:54: Download size: 45.2 MB
2021-01-19 09:21:05: Download completed
2021-01-19 09:21:07: Extracting [C:\Users\prigib\AppData\Local\Temp\ActivePresenter_updater_tmp\ActivePresenter_v7.5.15_update.zip] to [C:\Users\prigib\AppData\Local\Temp\ActivePresenter_updater_tmp\setup]ā¦
2021-01-19 09:21:09: Executing [C:\Users\prigib\AppData\Local\Temp\ActivePresenter_updater_tmp\rlupdater.exe C:\Program Files\ATOMI\ActivePresenter\ActivePresenter.exe C:\Users\prigib\AppData\Local\Temp\ActivePresenter_updater_tmp\setup\ActivePresenter_v7.5.15_update.exe]ā¦
2021-01-19 09:21:09: Running updaterā¦
2021-01-19 09:21:12: ActivePresenter 7.5.13 (Release Build: 2020.03.03) shut down
Hi Prigi,
We have checked the log and there is nothing wrong with it. Could you please describe the problem in more detail and send the full log so we can check? If the log file is long, you can send it to support@atomisystems.com
If the application crashed when you were recording the screen and you just found the 2 files above, there is no way to recover the video recording, unfortunately.
Hello,
What is the hotkey that causes recording to stop and not save? It happened to me the third time, and there is no trace in the backup
2021-02-20 15:53:21: Stop video recording. Frames recorded: 116243. Dropped: 2633. Duration: 4308661. Average FPS: 26.98
Please help, I donāt know what Iām pressing, but Iām loosing the recordingsā¦
Iām not sure which OS you are using, however, you can see the hotkey for stop recording in this dialog:
(Click the Gear icon in the Record Video Project/ Record Software Simulation Project dialog > Recording Settings > Hotkeys):
Yen
Thank you for the answer
Somehow I had to use this hot key Ctrl+ALt+C
Within the same project tried to save 2 different screen recordings, but did not save the video recordings. Log is as folllows. How can I recover the video recordings? on activepresenter video slides have āno video sourceā caption.
any help much appreciated.
2021-03-16 20:00:17: flt sample format is not supported, s16 will be used
2021-03-16 20:00:17: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2021-03-16 20:00:17: Preparing to record audio from: Background Music. Channel: 2. Sample rate: 48000. Sample Format: 8
2021-03-16 20:00:17: Failed to load icon: microphone_on_128_d.png
2021-03-16 20:00:17: Failed to load icon: capture_fullscreen_selected_128_d.png
2021-03-16 20:00:17: Failed to load icon: capture_customsize_128_d.png
2021-03-16 20:00:17: Failed to load icon: capture_fullscreen_128_d.png
2021-03-16 20:00:17: Failed to load icon: capture_customsize_selected_128_d.png
2021-03-16 20:00:17: Failed to load icon: microphone_off_128_d.png
2021-03-16 20:00:26: Start capturing. Mode: Full motion. Method: 0. Capture Size: (1391, 697)
2021-03-16 20:00:26: Video Codec: flashsv. Expecting FPS: 30.00
2021-03-16 20:00:26: Video will be recorded to: /Users/SergioRobles/Library/Application Support/ActivePresenter/temp/rl_20210316_200026_gjhj1harwc_tempdir/video_20210316_20-00-26.mkv
2021-03-16 20:00:26: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2021-03-16 20:00:26: flt sample format is not supported, s16 will be used
2021-03-16 20:00:26: Audio 2 will be recorded to: /Users/SergioRobles/Library/Application Support/ActivePresenter/temp/rl_20210316_200026_gjhj1harwc_tempdir/audio_20210316_20-00-26.wav
2021-03-16 20:00:26: Preparing to record audio from: Background Music. Channel: 2. Sample rate: 48000. Sample Format: 8
2021-03-16 20:00:29: Waiting to start in 3326
2021-03-16 21:02:56: Stop video recording. Frames recorded: 43613. Dropped: 55860. Duration: 3746068. Average FPS: 11.64
2021-03-16 21:02:58: RLMedia: Stream #0: not enough frames to estimate rate; consider increasing probesize
2021-03-16 21:02:58: Recorded video data size: 71745308 KB
2021-03-16 21:02:58: AddVideo2Slide: Time spend: 64 ms
2021-03-16 21:02:58: ProcessRecordedAudio: duration (ms) 3746176.000000
2021-03-16 21:03:57: Error: canāt write to file descriptor 93 (error 27: File too large)
2021-03-16 21:03:57: Error: Error copying the file ā/Users/SergioRobles/Library/Application Support/ActivePresenter/temp/rl_20210316_200026_gjhj1harwc_files/10000_Video_001.mkvā to ā/Volumes/DOS-BACKUP/eduCAP/teste2aula4_files/10012_.mkvā.
2021-03-16 21:04:10: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2021-03-16 21:04:37: flt sample format is not supported, s16 will be used
2021-03-16 21:04:37: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2021-03-16 21:04:37: Preparing to record audio from: Background Music. Channel: 2. Sample rate: 48000. Sample Format: 8
2021-03-16 21:04:37: Failed to load icon: microphone_on_128_d.png
2021-03-16 21:04:37: Failed to load icon: capture_fullscreen_selected_128_d.png
2021-03-16 21:04:37: Failed to load icon: capture_customsize_128_d.png
2021-03-16 21:04:37: Failed to load icon: capture_fullscreen_128_d.png
2021-03-16 21:04:37: Failed to load icon: capture_customsize_selected_128_d.png
2021-03-16 21:04:37: Failed to load icon: microphone_off_128_d.png
2021-03-16 21:04:51: flt sample format is not supported, s16 will be used
2021-03-16 21:04:51: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2021-03-16 21:04:51: Preparing to record audio from: Built-in Microph. Channel: 2. Sample rate: 48000. Sample Format: 8
2021-03-16 21:04:51: Failed to load icon: microphone_on_128_d.png
2021-03-16 21:04:55: Start capturing. Mode: Full motion. Method: 0. Capture Size: (1390, 695)
2021-03-16 21:04:55: Video Codec: flashsv. Expecting FPS: 30.00
2021-03-16 21:04:55: Video will be recorded to: /Users/SergioRobles/Library/Application Support/ActivePresenter/temp/rl_20210316_210455_ftoi4t56dv_tempdir/video_20210316_21-04-55.mkv
2021-03-16 21:04:55: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2021-03-16 21:04:55: flt sample format is not supported, s16 will be used
2021-03-16 21:04:55: Audio will be recorded to: /Users/SergioRobles/Library/Application Support/ActivePresenter/temp/rl_20210316_210455_ftoi4t56dv_tempdir/audio_20210316_21-04-55.wav
2021-03-16 21:04:55: Preparing to record audio from: Built-in Microph. Channel: 2. Sample rate: 48000. Sample Format: 8
2021-03-16 21:04:55: Audio 2 will be recorded to: /Users/SergioRobles/Library/Application Support/ActivePresenter/temp/rl_20210316_210455_ftoi4t56dv_tempdir/audio_20210316_21-04-55_1.wav
2021-03-16 21:04:55: Preparing to record audio from: Background Music. Channel: 2. Sample rate: 48000. Sample Format: 8
2021-03-16 21:04:58: Waiting to start in 3164
2021-03-16 21:35:49: Stop video recording. Frames recorded: 9410. Dropped: 42895. Duration: 1850243. Average FPS: 5.09
2021-03-16 21:35:51: Recorded video data size: 36409426 KB
2021-03-16 21:35:51: AddVideo2Slide: Time spend: 60 ms
2021-03-16 21:35:51: ProcessRecordedAudio: duration (ms) 1850325.333000
2021-03-16 21:35:51: ProcessRecordedAudio: duration (ms) 1850453.333000
2021-03-16 21:37:02: Error: canāt write to file descriptor 96 (error 27: File too large)
2021-03-16 21:37:02: Error: Error copying the file ā/Users/SergioRobles/Library/Application Support/ActivePresenter/temp/rl_20210316_210455_ftoi4t56dv_files/10000_Video_001.mkvā to ā/Volumes/DOS-BACKUP/eduCAP/teste2aula4_files/10015_.mkvā.
2021-03-16 21:37:13: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2021-03-16 21:37:18: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
Hi SergioRobles,
Could you please send us the full log so we can check.
Please save as file and send to us at email support@atomisystems.com.
Quynh
Hi there, I had a problem yesterday. I recorded a 2.30 hour video and was in the process of converting it to .MP4. Halfway through due to constraints in disk space the program hung up and i had to Force quit. I see a MP4 file which is 1.2GB on my desktop- which was the destination i gave. However i cannot play it on either VLC or on Quicktime- it does not show any duration. I tired to open the file using AP, but it does not work either. I am using the following version on my iMac.
ActivePresenter Free Edition
Version 8.0.5 (Released: 2020.04.10)
Copyright Ā© 2009 - 2020 Atomi Systems, Inc.
Thanks for any help.
Romesh
Hi Romesh,
Do you keep the ActivePresenter project file (.approj file)?
If yes, you can open it to export to MP4 again.
Otherwise, you can try using Handbrake (a free open source video transcoder) to convert your MP4 video to see if it works.
hello, today I started a video record with ActivePresenter like always. everything was okay but when I ended the record, there was an ActivePresenter logo in the middle of the screen with āloadingā. I am sure I used Record Video and not the other one. my laptop was open for 4 hours but nothing happened. my laptop got me always the option to close that because it was not reacting for 4 hours. I restarted my laptop and clicked on ActivePresenter. it opened and said āwould you like to restore your autsaved presentationā. I clicked on yes but there was nothing about a video, just a screen with an empty presentation. named: Untitled.approj
please help to get my record.
I saw that most people send their log.
2021-04-23 08:36:06: ActivePresenter 8.3.2 - 64-bit build. (Release Build: 2021.01.26) started
OS: Windows 10 (build 19042), 64-bit edition
CPU Count: 2
Hostname: laptopVolqan. Memory: 7,055 MB. Available: 2,249 MB. Memory Load: 68%
Disk Space: 120,826 MB (Free: 51,687 MB)
Project Location: C:\Users\volka\OneDrive\Documenten\ActivePresenter
2021-04-23 08:36:06: TempDir: C:\Users\volka\AppData\Roaming\ActivePresenter\temp
2021-04-23 08:36:07: Direct3D rendering mode: hardware
2021-04-23 08:36:07: Direct3D device type: 1
2021-04-23 08:36:41: Checking updates for ActivePresenter v8.3.2ā¦
2021-04-23 08:36:59: PrepareRibbonBar: 3483ms
2021-04-23 08:37:15: ---------------------LISTING WEBCAMS------------------------
2021-04-23 08:37:15: 1. Integrated Camera - \?\usb#vid_04f2&pid_b624&mi_00#7&3279ec87&1&0000#{e5323777-f976-4f5b-9b55-b94699c46e44}\global
2021-04-23 08:37:15: --------------------------------------------------------------
2021-04-23 08:37:17: flt sample format is not supported, s16 will be used
2021-04-23 08:37:17: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2021-04-23 08:37:17: Preparing to record audio from: Speakers (RealtekĀ® Audio). Channel: 2. Sample rate: 48000. Sample Format: 8
2021-04-23 08:37:17: Failed to load icon: microphone_on_64_d.png
2021-04-23 08:37:17: Failed to load icon: capture_fullscreen_selected_64_d.png
2021-04-23 08:37:17: Failed to load icon: capture_customsize_64_d.png
2021-04-23 08:37:17: Failed to load icon: capture_fullscreen_64_d.png
2021-04-23 08:37:17: Failed to load icon: capture_customsize_selected_64_d.png
2021-04-23 08:37:26: Failed to load icon: capture_fullscreen_selected_64_d.png
2021-04-23 08:37:26: Failed to load icon: capture_customsize_64_d.png
2021-04-23 08:37:36: flt sample format is not supported, s16 will be used
2021-04-23 08:37:36: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2021-04-23 08:37:36: Preparing to record audio from: Speakers (RealtekĀ® Audio). Channel: 2. Sample rate: 48000. Sample Format: 8
2021-04-23 08:37:37: flt sample format is not supported, s16 will be used
2021-04-23 08:37:37: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2021-04-23 08:37:37: Failed to load icon: microphone_on_64_d.png
2021-04-23 08:37:37: Preparing to record audio from: Speakers (RealtekĀ® Audio). Channel: 2. Sample rate: 48000. Sample Format: 8
2021-04-23 08:44:08: Failed to load icon: capture_fullscreen_selected_64_d.png
2021-04-23 08:44:08: Failed to load icon: capture_customsize_64_d.png
2021-04-23 08:44:09: Failed to load icon: capture_fullscreen_selected_64_d.png
2021-04-23 08:44:09: Failed to load icon: capture_customsize_64_d.png
2021-04-23 08:44:26: Start capturing. Mode: Full motion. Method: 0. Capture Size: (1920, 1080)
2021-04-23 08:44:26: Video Codec: flashsv. Expecting FPS: 30.00
2021-04-23 08:44:27: Video will be recorded to: C:\Users\volka\AppData\Roaming\ActivePresenter\temp\rl_20210423_084426_8ip7yorvgr_tempdir\video_20210423_08-44-27.mkv
2021-04-23 08:44:27: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2021-04-23 08:44:27: flt sample format is not supported, s16 will be used
2021-04-23 08:44:27: Audio 2 will be recorded to: C:\Users\volka\AppData\Roaming\ActivePresenter\temp\rl_20210423_084426_8ip7yorvgr_tempdir\audio_20210423_08-44-27.wav
2021-04-23 08:44:27: Preparing to record audio from: Speakers (RealtekĀ® Audio). Channel: 2. Sample rate: 48000. Sample Format: 8
2021-04-23 08:44:30: Waiting to start in 2883
2021-04-23 08:44:42: Failed to load icon: capture_continue_48_d.png
2021-04-23 09:34:43: Failed to load icon: capture_continue_48_d.png
2021-04-23 13:56:20: ActivePresenter 8.3.2 - 64-bit build. (Release Build: 2021.01.26) started
CPU Count: 2
Hostname: laptopVolqan. Memory: 7,055 MB. Available: 4,462 MB. Memory Load: 36%
Disk Space: 120,826 MB (Free: 46,744 MB)
2021-04-23 13:56:20: TempDir: C:\Users\volka\AppData\Roaming\ActivePresenter\temp
2021-04-23 13:56:20: Direct3D rendering mode: hardware
2021-04-23 13:56:20: Direct3D device type: 1
2021-04-23 13:56:44: Opening project: C:\Users\volka\AppData\Roaming\ActivePresenter\backup\2c3cc563-091d-491e-92da-817fd9a96c1f.approj
2021-04-23 13:56:46: PrepareRibbonBar: 1266ms
2021-04-23 13:56:53: Checking updates for ActivePresenter v8.3.2ā¦
2021-04-23 13:57:15: Render Project Size: 1280 x 720
2021-04-23 13:57:15: Threads Used: 1 / 2, Memory Available: 3,992/7,055
2021-04-23 13:57:15: Preparing to play audio to: Speakers (RealtekĀ® Audio). Channel: 2. Sample rate: 48000. Sample Format: 8
2021-04-23 13:57:15: Audio frames decoding started.
2021-04-23 13:57:15: Video frames decoding started.
2021-04-23 13:59:34: Render Project Size: 1280 x 720
2021-04-23 13:59:34: Threads Used: 1 / 2, Memory Available: 3,939/7,055
2021-04-23 13:59:34: MF Version: 131184
2021-04-23 13:59:34: s16 sample format is not supported, fltp will be used
2021-04-23 13:59:34: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2021-04-23 13:59:36: RLMedia: 2 frames left in the queue on closing
2021-04-23 13:59:36: Exporting video completed in 2 seconds.
2021-04-23 14:00:37: ActivePresenter 8.3.2 (Release Build: 2021.01.26) shut down
2021-04-23 14:00:41: ActivePresenter 8.3.2 - 64-bit build. (Release Build: 2021.01.26) started
CPU Count: 2
Hostname: laptopVolqan. Memory: 7,055 MB. Available: 4,183 MB. Memory Load: 40%
Disk Space: 120,826 MB (Free: 46,738 MB)
2021-04-23 14:00:42: TempDir: C:\Users\volka\AppData\Roaming\ActivePresenter\temp
2021-04-23 14:00:42: Direct3D rendering mode: hardware
2021-04-23 14:00:42: Direct3D device type: 1
2021-04-23 14:01:07: Opening project: C:\Users\volka\Desktop\Untitled.approj
2021-04-23 14:01:09: PrepareRibbonBar: 1125ms
2021-04-23 14:01:23: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2021-04-23 14:01:23: Render Project Size: 1280 x 720
2021-04-23 14:01:23: Threads Used: 1 / 2, Memory Available: 3,911/7,055
2021-04-23 14:01:23: Preparing to play audio to: Speakers (RealtekĀ® Audio). Channel: 2. Sample rate: 48000. Sample Format: 8
2021-04-23 14:01:23: Audio frames decoding started.
2021-04-23 14:01:23: Video frames decoding started.
2021-04-23 14:01:23: Preparing to record audio from: Microphone (RealtekĀ® Audio). Channel: 2. Sample rate: 48000. Sample Format: 8
2021-04-23 14:01:27: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2021-04-23 14:01:35: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2021-04-23 14:01:35: Render Project Size: 1280 x 720
2021-04-23 14:01:35: Threads Used: 1 / 2, Memory Available: 3,917/7,055
2021-04-23 14:01:35: Preparing to play audio to: Speakers (RealtekĀ® Audio). Channel: 2. Sample rate: 48000. Sample Format: 8
2021-04-23 14:01:35: Video frames decoding started.
2021-04-23 14:01:35: Audio frames decoding started.
2021-04-23 14:01:35: Preparing to record audio from: Microphone (RealtekĀ® Audio). Channel: 2. Sample rate: 48000. Sample Format: 8
2021-04-23 14:01:38: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2021-04-23 14:01:42: Render Project Size: 1280 x 720
2021-04-23 14:01:42: Threads Used: 1 / 2, Memory Available: 3,918/7,055
2021-04-23 14:01:42: Preparing to play audio to: Speakers (RealtekĀ® Audio). Channel: 2. Sample rate: 48000. Sample Format: 8
2021-04-23 14:01:42: Video frames decoding started.
2021-04-23 14:01:42: Audio frames decoding started.
2021-04-23 14:01:57: ActivePresenter 8.3.2 (Release Build: 2021.01.26) shut down
2021-04-23 14:06:23: ActivePresenter 8.3.2 - 64-bit build. (Release Build: 2021.01.26) started
CPU Count: 2
Hostname: laptopVolqan. Memory: 7,055 MB. Available: 4,139 MB. Memory Load: 41%
Disk Space: 120,826 MB (Free: 46,729 MB)
2021-04-23 14:06:23: TempDir: C:\Users\volka\AppData\Roaming\ActivePresenter\temp
2021-04-23 14:06:23: Direct3D rendering mode: hardware
2021-04-23 14:06:23: Direct3D device type: 1
2021-04-23 14:06:30: Opening project: C:\Users\volka\Desktop\Untitled.approj
2021-04-23 14:06:32: PrepareRibbonBar: 1550ms
2021-04-23 14:06:53: ActivePresenter 8.3.2 (Release Build: 2021.01.26) shut down
2021-04-23 14:23:58: ActivePresenter 8.3.2 - 64-bit build. (Release Build: 2021.01.26) started
CPU Count: 2
Hostname: laptopVolqan. Memory: 7,055 MB. Available: 3,733 MB. Memory Load: 47%
2021-04-23 14:23:58: TempDir: C:\Users\volka\AppData\Roaming\ActivePresenter\temp
2021-04-23 14:23:58: Direct3D rendering mode: hardware
2021-04-23 14:23:58: Direct3D device type: 1
2021-04-23 14:25:04: ---------------------LISTING WEBCAMS------------------------
2021-04-23 14:25:04: 1. Integrated Camera - \?\usb#vid_04f2&pid_b624&mi_00#7&3279ec87&1&0000#{e5323777-f976-4f5b-9b55-b94699c46e44}\global
2021-04-23 14:25:04: --------------------------------------------------------------
2021-04-23 14:25:04: flt sample format is not supported, s16 will be used
2021-04-23 14:25:04: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2021-04-23 14:25:04: Preparing to record audio from: Speakers (RealtekĀ® Audio). Channel: 2. Sample rate: 48000. Sample Format: 8
2021-04-23 14:25:05: flt sample format is not supported, s16 will be used
2021-04-23 14:25:05: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2021-04-23 14:25:05: Failed to load icon: microphone_on_64_d.png
2021-04-23 14:25:05: Failed to load icon: capture_fullscreen_selected_64_d.png
2021-04-23 14:25:05: Failed to load icon: capture_customsize_64_d.png
2021-04-23 14:25:05: Failed to load icon: capture_fullscreen_64_d.png
2021-04-23 14:25:05: Failed to load icon: capture_customsize_selected_64_d.png
2021-04-23 14:25:05: Preparing to record audio from: Speakers (RealtekĀ® Audio). Channel: 2. Sample rate: 48000. Sample Format: 8
2021-04-23 14:26:11: Opening project: C:\Users\volka\Desktop\Untitled.approj
2021-04-23 14:26:13: PrepareRibbonBar: 1195ms
2021-04-23 14:26:48: ActivePresenter 8.3.2 (Release Build: 2021.01.26) shut down
2021-04-23 14:26:49: ActivePresenter 8.3.2 - 64-bit build. (Release Build: 2021.01.26) started
CPU Count: 2
Hostname: laptopVolqan. Memory: 7,055 MB. Available: 3,755 MB. Memory Load: 46%
Disk Space: 120,826 MB (Free: 46,742 MB)
2021-04-23 14:26:49: TempDir: C:\Users\volka\AppData\Roaming\ActivePresenter\temp
2021-04-23 14:26:49: Direct3D rendering mode: hardware
2021-04-23 14:26:49: Direct3D device type: 1
Hi ,
Could you please take a look at the cached folder (C:\Users\Username\Documents\ActivePresenter.ActivePresenterCachedProjects) to see if there are any audio/ video files?
ā.ActivePresenterCachedProjectsā is a hidden folder so you might need to turn on the āShow Hidden Filesā option to see it.
If there are video files here, you can copy them to another folder and open with ActivePresenter for editing.
Besides, kindly take note that ActivePresenter is mainly designed for creating training tutorials that normally have a duration of fewer than 1 hour. If you want to record a long session, you should look around for other screen recorders on the Internet.
Yen
Hi Yen,
I donāt have those video files, I have 2 files of 1kb and it is not possible to open them in ActivePresenter.
Which screen recorder do you prefer? At the moment I just downloaded OBS studio but I donāt know what kind of program it is.
Thanks
If so, Iām afraid that there is no way to recover the video.
Yen
Hello,
I had completed recording a session & opened another session to record but somehow it got crashed.
Now I find the audio file of the first session by checking the Logs but couldnāt find video of it, itās not there.
there is no trace of my second recording and it seems that recoding wasnāt even took place.
now how can I find the video of first session? I can see there a file saved with file type as just File which belongs to my first session but I canāt open it up in Activepresenter.
FYI here are my Logs,
2021-12-20 11:30:59: ActivePresenter 8.5.2 - 64-bit build. (Release Build: 2021.09.10) started
CPU Count: 12
Hostname: LW10CAMIS03PPAT. Memory: 7,902 MB. Available: 1,648 MB. Memory Load: 79%
Disk Space: 241,127 MB (Free: 72,798 MB)
Project Location: C:\Users\PrerPatel\Documents\ActivePresenter
2021-12-20 11:30:59: TempDir: C:\Users\PrerPatel\AppData\Roaming\ActivePresenter\temp
2021-12-20 11:30:59: Direct3D rendering mode: hardware
2021-12-20 11:30:59: Direct3D device type: 1
2021-12-20 11:31:03: ---------------------LISTING WEBCAMS------------------------
2021-12-20 11:31:03: 1. Integrated Camera - \?\usb#vid_04f2&pid_b604&mi_00#6&31e07f50&0&0000#{e5323777-f976-4f5b-9b55-b94699c46e44}\global
2021-12-20 11:31:03: --------------------------------------------------------------
2021-12-20 11:31:04: flt sample format is not supported, s16 will be used
2021-12-20 11:31:04: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2021-12-20 11:31:04: Preparing to record audio from: Microphone Array (Realtek(R) Audio). Channel: 2. Sample rate: 48000. Sample Format: 8
2021-12-20 11:31:05: flt sample format is not supported, s16 will be used
2021-12-20 11:31:05: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2021-12-20 11:31:05: Preparing to record audio from: Microphone Array (Realtek(R) Audio). Channel: 2. Sample rate: 48000. Sample Format: 8
2021-12-20 11:31:17: Start capturing. Mode: Full motion. Method: 0. Capture Size: (1920, 1080)
2021-12-20 11:31:17: Video Codec: h264_mf. Expecting FPS: 30.00
2021-12-20 11:31:17: Video will be recorded to: C:\Users\PrerPatel\Documents\ActivePresenter.ActivePresenterCachedProjects\Untitled2_tempdir\video_20211220_11-31-17.mkv
2021-12-20 11:31:17: bgr24 pixel format is not supported, nv12 will be used
2021-12-20 11:31:17: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2021-12-20 11:31:17: flt sample format is not supported, s16 will be used
2021-12-20 11:31:17: Audio will be recorded to: C:\Users\PrerPatel\Documents\ActivePresenter.ActivePresenterCachedProjects\Untitled2_tempdir\audio_20211220_11-31-17.wav
2021-12-20 11:31:17: Preparing to record audio from: Microphone Array (Realtek(R) Audio). Channel: 2. Sample rate: 48000. Sample Format: 8
2021-12-20 11:31:17: Audio 2 will be recorded to: C:\Users\PrerPatel\Documents\ActivePresenter.ActivePresenterCachedProjects\Untitled2_tempdir\audio_20211220_11-31-17_1.wav
2021-12-20 11:31:17: Preparing to record audio from: Speaker/HP (Realtek(R) Audio). Channel: 2. Sample rate: 48000. Sample Format: 8
2021-12-20 11:31:20: Waiting to start in 3249
2021-12-20 11:37:17: PrepareRibbonBar: 550ms
2021-12-20 11:37:15: Stop video recording. Frames recorded: 10383. Dropped: 0. Duration: 354664. Average FPS: 29.27
2021-12-20 11:37:15: Recorded video data size: 42434 KB
2021-12-20 11:37:16: AddVideo2Slide: Time spend: 931 ms
2021-12-20 11:37:16: ProcessRecordedAudio: duration (ms) 354745.271000
2021-12-20 11:37:16: ProcessRecordedAudio: duration (ms) 354748.979000
2021-12-20 11:37:19: RLMedia: No streams to mux were specified
2021-12-20 11:37:19: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2021-12-20 11:37:20: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2021-12-20 11:37:27: ---------------------LISTING WEBCAMS------------------------
2021-12-20 11:37:27: 1. Integrated Camera - \?\usb#vid_04f2&pid_b604&mi_00#6&31e07f50&0&0000#{e5323777-f976-4f5b-9b55-b94699c46e44}\global
2021-12-20 11:37:27: --------------------------------------------------------------
2021-12-20 11:37:27: flt sample format is not supported, s16 will be used
2021-12-20 11:37:27: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2021-12-20 11:37:27: Preparing to record audio from: Microphone Array (Realtek(R) Audio). Channel: 2. Sample rate: 48000. Sample Format: 8
2021-12-20 11:37:31: Checking updates for ActivePresenter v8.5.2ā¦
2021-12-20 11:37:31: Checking updates, creating taskā¦
2021-12-20 11:37:31: New updates available: 8.5.4
2021-12-20 11:37:35: Start capturing. Mode: Full motion. Method: 0. Capture Size: (1920, 1080)
2021-12-20 11:37:35: Video Codec: h264_mf. Expecting FPS: 30.00
Hello,
I had a long screen recording (4 and a half hours) earlier today and when I wanted to stop it, the recording toolbar just disappeared. My hard disc is showing me that it has to be somewhere because it is full (before it had 7 GB of free space) but I canāt find it anywhere (itās not in the cached folder). What can I do?
Hi Marko,
Can you send the log so we can take a look?
To view the log:
- On Start Page, click Preferences (the Gear icon).
- In the Preferences dialog, select the Miscellaneous tab.
- Click View Log.
You can follow the guiding steps through this video: https://www.youtube.com/watch?v=qdt7Z5h5bVc&t=3s
Huyen
I had a long screen recording (9 hours a half hours) yesterday. I already make sure the recording is on going but after i click stop to record, the record was only 4 hours and the less was missing.
2023-01-08 09:23:48: ActivePresenter 9.0.3 - 64-bit build. (Release Build: 2022.10.28) started
OS: Windows 11 (build 22000), 64-bit edition
CPU Count: 8
Hostname: TP-LT-2105-007. Memory: 8,032 MB. Available: 1,091 MB. Memory Load: 86%
Disk Space: 243,020 MB (Free: 135,687 MB)
Project Location: C:\Users\credit4\Documents\ActivePresenter
2023-01-08 09:23:48: TempDir: C:\Users\credit4\AppData\Roaming\ActivePresenter\temp
2023-01-08 09:23:48: -----------------LISTING GRAPHICS DEVICES---------------------
2023-01-08 09:23:48: DXGIAdapter: Intel(R) UHD Graphics (0-68902)
2023-01-08 09:23:48: DXGIAdapter: Microsoft Basic Render Driver (0-69965)
2023-01-08 09:23:48: DXGIAdapter Intel(R) UHD Graphics (0-68902) is used.
2023-01-08 09:23:48: --------------------------------------------------------------
2023-01-08 09:23:48: ---------------------LISTING AUDIO DEVICES------------------------
2023-01-08 09:23:48: Speakers (Realtek(R) Audio) (API: Windows WASAPI, Input: 2, Output: 2, Rate: 48000, Loopback: true, Default Output: true, ID: {0.0.0.00000000}.{04635452-7cfe-4c4e-b22c-5030c7f1660b})
2023-01-08 09:23:48: Microphone (Realtek(R) Audio) (API: Windows WASAPI, Input: 2, Output: 0, Rate: 48000, Loopback: false, Default Output: false, ID: {0.0.1.00000000}.{32e9c935-4057-47d4-a39b-a2f52c48344d})
2023-01-08 09:23:50: ---------------------LISTING WEBCAMS------------------------
2023-01-08 09:23:50: 1. USB2.0 HD UVC WebCam - \?\usb#vid_13d3&pid_56a2&mi_00#6&c91c3a9&0&0000#{e5323777-f976-4f5b-9b55-b94699c46e44}\global
2023-01-08 09:23:50: --------------------------------------------------------------
2023-01-08 09:23:56: PrepareRibbonBar: 4880ms
2023-01-08 09:23:57: MKAudioRecorder::Open: Device: {0.0.0.00000000}.{04635452-7cfe-4c4e-b22c-5030c7f1660b}, File: C:\Users\credit4\AppData\Roaming\ActivePresenter\temp\rl_20230108_092357_vftsicvf7x.wav, Params: codec: 0, format: Sample Format 5, channel: 2, frame_size: 0, rate: 48000.000000, bit_rate: 0, quality: 0
2023-01-08 09:23:57: Probing to record audio from: Speakers (Realtek(R) Audio). Channel: 2. Sample rate: 48000. Pa Sample Format: 1
2023-01-08 09:23:57: Open audio device successes!
2023-01-08 09:23:57: flt sample format is not supported, s16 will be used
2023-01-08 09:24:01: Start capturing. Mode: Full motion. Capture Size: (1920, 1080)
2023-01-08 09:24:01: MKScreenRecorder::Open: Engine:2, File: C:\Users\credit4\Documents\ActivePresenter.ActivePresenterCachedProjects\Untitled_tempdir\video_20230108_09-24-01.mp4, Params: codec: 10001, format: NV12, width: 1920, height: 1080, color_range: 8, rate: 30.000000, bit_rate: 0, quality: 90
2023-01-08 09:24:01: Encoder: - h264_mf
2023-01-08 09:24:01: MKAudioRecorder::Open: Device: {0.0.0.00000000}.{04635452-7cfe-4c4e-b22c-5030c7f1660b}, File: C:\Users\credit4\Documents\ActivePresenter.ActivePresenterCachedProjects\Untitled_tempdir\audio_2_20230108_09-24-01.wav, Params: codec: 0, format: Sample Format 5, channel: 2, frame_size: 0, rate: 48000.000000, bit_rate: 0, quality: 0
2023-01-08 09:24:01: Probing to record audio from: Speakers (Realtek(R) Audio). Channel: 2. Sample rate: 48000. Pa Sample Format: 1
2023-01-08 09:24:01: Open audio device successes!
2023-01-08 09:24:01: flt sample format is not supported, s16 will be used
2023-01-08 19:12:11: MKScreenCaptureD2DImpl:StopCapture Frame: 401863, Drop: 4, Encoded FPS 29.583212, Captured FPS 29.583286, Time: 13584.123248s
2023-01-08 19:12:11: RLMedia: Filesize 6775111598 invalid for wav, output file will be broken
2023-01-08 19:12:11: Recorded video data size: 3.4 GB
2023-01-08 19:12:12: RLMedia: Ignoring maximum wav data size, file may be invalid
2023-01-08 19:12:12: RLMedia: Estimating duration from bitrate, this may be inaccurate
2023-01-08 19:12:12: ProcessRecordedAudio: duration (ms) 35287039
2023-01-08 19:12:13: Checking updates for ActivePresenter v9.0.3ā¦
2023-01-08 19:12:16: New updates available: 9.0.5
2023-01-08 19:12:16: RLMedia: Ignoring maximum wav data size, file may be invalid
2023-01-08 19:12:16: RLMedia: Estimating duration from bitrate, this may be inaccurate
2023-01-08 19:14:52: RLSQLite exception 1, SQL logic error[1]: cannot commit - no transaction is active
2023-01-08 19:15:26: RLMedia: Ignoring maximum wav data size, file may be invalid
2023-01-08 19:15:26: RLMedia: Estimating duration from bitrate, this may be inaccurate
2023-01-08 19:15:26: Render Project Size: 1920 x 1080
2023-01-08 19:15:26: Threads Used: 5 / 8, Memory Available: 2,851/8,032
2023-01-08 19:15:26: Encoder: Windows Media Foundation - h264_mf
2023-01-08 21:59:38: Exporting video completed in 9853 seconds.
2023-01-08 22:19:26: RLMedia: Ignoring maximum wav data size, file may be invalid
2023-01-08 22:19:26: RLMedia: Estimating duration from bitrate, this may be inaccurate
2023-01-08 22:19:26: Render Project Size: 1920 x 1080
2023-01-08 22:19:26: Threads Used: 4 / 8, Memory Available: 2,698/8,032
2023-01-08 22:19:26: Probing to play audio from: Speakers (Realtek(R) Audio). Channel: 2. Sample rate: 48000. Pa Sample Format: 8
2023-01-08 22:19:26: Open audio device successes!
2023-01-08 22:21:04: Opening project: C:\BI\To convert\8 Jan 23.approj
2023-01-08 22:21:05: RLMedia: Ignoring maximum wav data size, file may be invalid
2023-01-08 22:21:05: RLMedia: Estimating duration from bitrate, this may be inaccurate
2023-01-08 22:21:20: RLMedia: Ignoring maximum wav data size, file may be invalid
2023-01-08 22:21:20: RLMedia: Estimating duration from bitrate, this may be inaccurate
2023-01-08 22:21:20: Render Project Size: 1920 x 1080
2023-01-08 22:21:20: Threads Used: 4 / 8, Memory Available: 2,309/8,032
2023-01-08 22:21:20: Probing to play audio from: Speakers (Realtek(R) Audio). Channel: 2. Sample rate: 48000. Pa Sample Format: 8
2023-01-08 22:21:21: Open audio device successes!
2023-01-08 22:24:32: RLMedia: Ignoring maximum wav data size, file may be invalid
2023-01-08 22:24:32: RLMedia: Estimating duration from bitrate, this may be inaccurate
2023-01-08 22:24:32: Render Project Size: 1920 x 1080
2023-01-08 22:24:32: Threads Used: 4 / 8, Memory Available: 2,168/8,032
2023-01-08 22:24:32: Probing to play audio from: Speakers (Realtek(R) Audio). Channel: 2. Sample rate: 48000. Pa Sample Format: 8
2023-01-08 22:24:33: Open audio device successes!
2023-01-08 22:26:21: RLSQLite exception 1, SQL logic error[1]: cannot commit - no transaction is active
2023-01-08 22:30:26: RLMedia: Ignoring maximum wav data size, file may be invalid
2023-01-08 22:30:26: RLMedia: Estimating duration from bitrate, this may be inaccurate
2023-01-08 22:30:26: Render Project Size: 1920 x 1080
2023-01-08 22:30:26: Threads Used: 4 / 8, Memory Available: 2,235/8,032
2023-01-08 22:30:26: Probing to play audio from: Speakers (Realtek(R) Audio). Channel: 2. Sample rate: 48000. Pa Sample Format: 8
2023-01-08 22:30:26: Open audio device successes!
2023-01-08 22:31:21: ActivePresenter 9.0.3 (Release Build: 2022.10.28) shut down
2023-01-08 22:31:42: ActivePresenter 9.0.3 - 64-bit build. (Release Build: 2022.10.28) started
CPU Count: 8
Hostname: TP-LT-2105-007. Memory: 8,032 MB. Available: 2,979 MB. Memory Load: 62%
Disk Space: 243,020 MB (Free: 102,164 MB)
2023-01-08 22:31:42: TempDir: C:\Users\credit4\AppData\Roaming\ActivePresenter\temp
2023-01-08 22:31:42: -----------------LISTING GRAPHICS DEVICES---------------------
2023-01-08 22:31:42: DXGIAdapter: Intel(R) UHD Graphics (0-68902)
2023-01-08 22:31:42: DXGIAdapter: Microsoft Basic Render Driver (0-69965)
2023-01-08 22:31:42: DXGIAdapter Intel(R) UHD Graphics (0-68902) is used.
2023-01-08 22:31:42: --------------------------------------------------------------
2023-01-08 22:31:43: ---------------------LISTING AUDIO DEVICES------------------------
2023-01-08 22:31:43: Speakers (Realtek(R) Audio) (API: Windows WASAPI, Input: 2, Output: 2, Rate: 48000, Loopback: true, Default Output: true, ID: {0.0.0.00000000}.{04635452-7cfe-4c4e-b22c-5030c7f1660b})
2023-01-08 22:31:43: Microphone (Realtek(R) Audio) (API: Windows WASAPI, Input: 2, Output: 0, Rate: 48000, Loopback: false, Default Output: false, ID: {0.0.1.00000000}.{32e9c935-4057-47d4-a39b-a2f52c48344d})
2023-01-08 22:31:43: --------------------------------------------------------------
2023-01-08 22:31:44: ---------------------LISTING WEBCAMS------------------------
2023-01-08 22:31:44: 1. USB2.0 HD UVC WebCam - \?\usb#vid_13d3&pid_56a2&mi_00#6&c91c3a9&0&0000#{e5323777-f976-4f5b-9b55-b94699c46e44}\global
2023-01-08 22:31:44: --------------------------------------------------------------
2023-01-08 22:31:46: PrepareRibbonBar: 948ms
2023-01-08 22:32:08: ActivePresenter 9.0.3 (Release Build: 2022.10.28) shut down
2023-01-08 22:37:58: ActivePresenter 9.0.3 - 64-bit build. (Release Build: 2022.10.28) started
CPU Count: 8
Hostname: TP-LT-2105-007. Memory: 8,032 MB. Available: 2,633 MB. Memory Load: 67%
Disk Space: 243,020 MB (Free: 102,289 MB)
2023-01-08 22:37:58: TempDir: C:\Users\credit4\AppData\Roaming\ActivePresenter\temp
2023-01-08 22:37:58: -----------------LISTING GRAPHICS DEVICES---------------------
2023-01-08 22:37:58: DXGIAdapter: Intel(R) UHD Graphics (0-68902)
2023-01-08 22:37:58: DXGIAdapter: Microsoft Basic Render Driver (0-69965)
2023-01-08 22:37:58: DXGIAdapter Intel(R) UHD Graphics (0-68902) is used.
2023-01-08 22:37:58: --------------------------------------------------------------
2023-01-08 22:37:58: ---------------------LISTING AUDIO DEVICES------------------------
2023-01-08 22:37:58: Speakers (Realtek(R) Audio) (API: Windows WASAPI, Input: 2, Output: 2, Rate: 48000, Loopback: true, Default Output: true, ID: {0.0.0.00000000}.{04635452-7cfe-4c4e-b22c-5030c7f1660b})
2023-01-08 22:37:58: Microphone (Realtek(R) Audio) (API: Windows WASAPI, Input: 2, Output: 0, Rate: 48000, Loopback: false, Default Output: false, ID: {0.0.1.00000000}.{32e9c935-4057-47d4-a39b-a2f52c48344d})
2023-01-08 22:37:59: ---------------------LISTING WEBCAMS------------------------
2023-01-08 22:37:59: 1. USB2.0 HD UVC WebCam - \?\usb#vid_13d3&pid_56a2&mi_00#6&c91c3a9&0&0000#{e5323777-f976-4f5b-9b55-b94699c46e44}\global
2023-01-08 22:37:59: --------------------------------------------------------------
2023-01-08 22:38:00: Opening project: C:\BI\To convert\8 Jan 23.approj
2023-01-08 22:38:01: PrepareRibbonBar: 1048ms
2023-01-08 22:38:02: RLMedia: Ignoring maximum wav data size, file may be invalid
2023-01-08 22:38:02: RLMedia: Estimating duration from bitrate, this may be inaccurate
2023-01-08 22:38:15: RLMedia: Ignoring maximum wav data size, file may be invalid
2023-01-08 22:38:15: RLMedia: Estimating duration from bitrate, this may be inaccurate
2023-01-08 22:38:15: Render Project Size: 1920 x 1080
2023-01-08 22:38:15: Threads Used: 4 / 8, Memory Available: 2,111/8,032
2023-01-08 22:38:15: Probing to play audio from: Speakers (Realtek(R) Audio). Channel: 2. Sample rate: 48000. Pa Sample Format: 8
2023-01-08 22:38:16: Open audio device successes!
2023-01-08 22:38:21: ActivePresenter 9.0.3 (Release Build: 2022.10.28) shut down
2023-01-08 22:45:10: ActivePresenter 9.0.3 - 64-bit build. (Release Build: 2022.10.28) started
CPU Count: 8
Hostname: TP-LT-2105-007. Memory: 8,032 MB. Available: 3,366 MB. Memory Load: 58%
Disk Space: 243,020 MB (Free: 102,318 MB)
2023-01-08 22:45:10: TempDir: C:\Users\credit4\AppData\Roaming\ActivePresenter\temp
2023-01-08 22:45:10: -----------------LISTING GRAPHICS DEVICES---------------------
2023-01-08 22:45:10: DXGIAdapter: Intel(R) UHD Graphics (0-68902)
2023-01-08 22:45:10: DXGIAdapter: Microsoft Basic Render Driver (0-69965)
2023-01-08 22:45:10: DXGIAdapter Intel(R) UHD Graphics (0-68902) is used.
2023-01-08 22:45:10: --------------------------------------------------------------
2023-01-08 22:45:10: ---------------------LISTING AUDIO DEVICES------------------------
2023-01-08 22:45:10: Speakers (Realtek(R) Audio) (API: Windows WASAPI, Input: 2, Output: 2, Rate: 48000, Loopback: true, Default Output: true, ID: {0.0.0.00000000}.{04635452-7cfe-4c4e-b22c-5030c7f1660b})
2023-01-08 22:45:10: Microphone (Realtek(R) Audio) (API: Windows WASAPI, Input: 2, Output: 0, Rate: 48000, Loopback: false, Default Output: false, ID: {0.0.1.00000000}.{32e9c935-4057-47d4-a39b-a2f52c48344d})
2023-01-08 22:45:11: ---------------------LISTING WEBCAMS------------------------
2023-01-08 22:45:11: 1. USB2.0 HD UVC WebCam - \?\usb#vid_13d3&pid_56a2&mi_00#6&c91c3a9&0&0000#{e5323777-f976-4f5b-9b55-b94699c46e44}\global
2023-01-08 22:45:11: --------------------------------------------------------------
2023-01-08 22:45:13: PrepareRibbonBar: 885ms
2023-01-08 22:45:14: MKAudioRecorder::Open: Device: {0.0.0.00000000}.{04635452-7cfe-4c4e-b22c-5030c7f1660b}, File: C:\Users\credit4\AppData\Roaming\ActivePresenter\temp\rl_20230108_224514_jjlkdy40n1.wav, Params: codec: 0, format: Sample Format 5, channel: 2, frame_size: 0, rate: 48000.000000, bit_rate: 0, quality: 0
2023-01-08 22:45:14: Probing to record audio from: Speakers (Realtek(R) Audio). Channel: 2. Sample rate: 48000. Pa Sample Format: 1
2023-01-08 22:45:14: Open audio device successes!
2023-01-08 22:45:14: flt sample format is not supported, s16 will be used
2023-01-08 22:45:16: Start capturing. Mode: Full motion. Capture Size: (1366, 768)
2023-01-08 22:45:16: MKScreenRecorder::Open: Engine:2, File: C:\Users\credit4\Documents\ActivePresenter.ActivePresenterCachedProjects\Untitled_tempdir\video_20230108_22-45-16.mp4, Params: codec: 10001, format: NV12, width: 1366, height: 768, color_range: 8, rate: 30.000000, bit_rate: 0, quality: 90
2023-01-08 22:45:16: Encoder: - h264_mf
2023-01-08 22:45:16: MKAudioRecorder::Open: Device: {0.0.0.00000000}.{04635452-7cfe-4c4e-b22c-5030c7f1660b}, File: C:\Users\credit4\Documents\ActivePresenter.ActivePresenterCachedProjects\Untitled_tempdir\audio_2_20230108_22-45-16.wav, Params: codec: 0, format: Sample Format 5, channel: 2, frame_size: 0, rate: 48000.000000, bit_rate: 0, quality: 0
2023-01-08 22:45:16: Probing to record audio from: Speakers (Realtek(R) Audio). Channel: 2. Sample rate: 48000. Pa Sample Format: 1
2023-01-08 22:45:16: Open audio device successes!
2023-01-08 22:45:16: flt sample format is not supported, s16 will be used
2023-01-08 22:47:39: MKScreenCaptureD2DImpl:StopCapture Frame: 4538, Drop: 0, Encoded FPS 32.562458, Captured FPS 32.569635, Time: 139.332235s
2023-01-08 22:47:39: Recorded video data size: 36.1 MB
2023-01-08 22:47:40: ProcessRecordedAudio: duration (ms) 139923
2023-01-08 22:48:01: Render Project Size: 1366 x 768
2023-01-08 22:48:01: Threads Used: 3 / 8, Memory Available: 1,973/8,032
2023-01-08 22:48:01: Probing to play audio from: Speakers (Realtek(R) Audio). Channel: 2. Sample rate: 48000. Pa Sample Format: 8
2023-01-08 22:48:01: Open audio device successes!
2023-01-08 22:50:01: Encoder: Windows Media Foundation, Codecs: 10001 10002
2023-01-08 22:52:04: Render Project Size: 1366 x 768
2023-01-08 22:52:04: Threads Used: 4 / 8, Memory Available: 2,862/8,032
2023-01-08 22:52:04: Probing to play audio from: Speakers (Realtek(R) Audio). Channel: 2. Sample rate: 48000. Pa Sample Format: 8
2023-01-08 22:52:05: Open audio device successes!
2023-01-08 22:52:59: ActivePresenter 9.0.3 (Release Build: 2022.10.28) shut down
