Problem: Is there an easy way to insert Lottie animation. I managed to insert it only using Lottie embed Iframe but it inserts it in a weird way. May be there is any plugins for that
ActivePresenter version: 8
OS: MS Windows 10
OS: MS Windows 10
Hi Ruslan,
To insert Lottie animations from LottieFiles to ActivePresenter, you add the src in the iframe code as follows:
For example, the iframe code in LottieFiles is <iframe src="https://embed.lottiefiles.com/animation/108681"></iframe>
You add the src inside the quotation marks to the URL Address in the Insert Web Object dialog (Insert tab > Web Object):
Hang
Awesome thank you so much
