Hi Andreas,
I’ve checked your project and see that you exported to SCORM 1.2 format.
Is it right?
SCORM 1.2 has only one variable lesson_status
for both completion and success status.
This variable can have one of the following values: incomplete, completed, passed, failed, browsed, not attempted
ActivePresenter will use incomplete/completed
values for Demonstration mode. In other modes (Tutorial, Practice, Test), the variable value will be set to passed
or failed
when the user completes the scorm.
Maybe your LMS doesn’t consider passed
and failed
value as completed so you see the completion status is incomplete. For example, when the user completes a SCORM 1.2 package, SCORM Cloud displays Success status correctly, but Completion status as incomplete:
