Problem: I am on a question page with checkboxes and activate a checkbox. Then I click on the submit button and a feedback layer appears. On the feedback layer there is a button. With this Button I come back to the interaction slide to repeat the quest. By clicking on the back button, all previous interactions should be reset. How is that supposed to work? We have already tried Action Clear User Input. But it didn’t work.
You should place the Clear User Input action after the Show Feedback Layer action.
ClearUserInput.approj (436 KB)
Thank you so much this has worked with the questions. We still have the issue of not saving progress. I tried out on Scorm Cloud and it worked fine on here but not in our LMS
Please refer here to get the solution, Linda: Not saving progress - #12 by PhuongThuy_Le
