Is there a way to change the design of the cursor from the default arrow to something else when it hovers over a specific object?
Can the design of the cursor be different for different objects?
Thanks!
Shawn
Thanks!
Shawn
Select the element, then properties pane (normally on the right) general section and use the icon at the end of the cursor box.
Great.
Is there a way to integrate our own design?
Yes, but I think you have to use CSS.
In the class name field in the image above enter âcustom-cursorâ without the speech marks. Then on the document pane, select Edit CSS and add the following code:
.custom-cursor {
cursor: url(resources/cursor.png), auto;
The Class Name on your element must match the class name used in the CSS.
The cursor.png name must match your resource name for the cursor. Iâve added the image to the resource pane for simplicity.
If youâre using it on IE, then the format must be of type .cur not png.
Indeed, custom cursor can be typed directly into the Cursor property field.
Hi Toan Le,
Thatâs what I would have thought as well but I couldnât figure out what value goes in the box to make the custom cursor work?
Hi Mack,
You should type only CSS value:
Unfortunately, in preview, resources folder is different so it only works when exporting to HTML5.
Thanks, I didnât include the â,autoâ bit which is why that didnât work.
I LOVE SAOLA ANIMATE!, I need help with the custom cursor, I canât get it to work! I did all the steps but it doesnât work, could you give me an example file?
Thank you very much for responding so quickly!! You are amazing!!
