Solved!
Thanks Toan!!!
Hi @ToanLS ,
if in a question I would to insert an image (as title of the question or as option of answer).
how could I proceed, without create a new layer?
Thanks
It’s not possible to insert images into a Multiple Choice question.
But you can insert images as separated layers and update the script as follows:
- Add array of image objects’ names to the question data, for example:
title: 'Q1_P1_Title',
question: 'Q1_P1',
images: ['Q1_P1_Img1', 'Q1_P1_Img2']
- Add script to show/hide images in
myShowQuestion
function
prez.myShowQuestion = function(show) {
if (!this.myShowingQuestion)
return;
var images = this.myShowingQuestion.images;
if (images) {
for (var i = 0; i < images.length; ++i) {
var imageObject = this.object(images[i]);
if (show)
imageObject.show();
else
imageObject.hide();
//..... (original code from if (show) {
I have solved! Thanks
Dear @ToanLS,
I bought 3 licenses of the software.
Now, the script works fine.
The only problem is:
(example)
If I set a range for the a poll of questions from 0.10 to 0.15 sec
and I don’t pause or restart the video before this range, all works good.
But if I pause the video before the range or restart the video, the range pool appears before.
What is the problem in the script?
Can you please let me know your order reference number or the email your placed the order?
My script use setTimeout
function for showing the question randomly so it’ll not work correctly if you pause or seek (e.g. restart, go to another slide) the presentation.
Hi Toan,
It works!
Thanks
Hi @ToanLS,
Could I set for the random question a timeout of 30 seconds for the student?
I cannot find the timeout option.
Thanks
Unfortunately, timeout option in the editor is not available for initially hidden questions.
You can add the following script to the end of myShowQuestion
function to show next section or restart current section when timeout occurs:
original code....
// add more for timeout
if (show) { // set timeout when showing the question
this.myQuestionTimeoutTimer = setTimeout(function() {
// show next section
prez.myShowNextSection(); // prez.myRestartSection(); if you want to restart current section
}, 30000); // 30s
} else { // clear timeout when hiding the question
if (this.myQuestionTimeoutTimer) {
clearTimeout(this.myQuestionTimeoutTimer);
delete this.myQuestionTimeoutTimer;
Hi @ToanLS,
thanks for your reply.
It works, but if the 30 seconds ends, the user must to see a timeout message and return at the beginning of the video.
To save the time please list all requirements clearly at once.
Hi @ToanLS
You are right, sorry.
I need only to fix these last 2 problems:
This:
And this:
Another problem is that when you minimize the window, the video go on, and so the random question not appears correctly.
This one is a big problem, the video must to be stopped when minimize the window.
Please check this sample: recreate-random-questions-at-random-time-3.approj (3.5 MB)
You’ll need to:
Update the script in Project Event
Add action
Execute JavaScript: prez.myClearQuestionTimeout();
add the beginning of On Correct / On Incorrect event of each question
Change the On Click actions of the Continue button in Timeout feedback
Regarding the issue #2, it’s due to recent changes in Chromium based browsers. We’ll fix it soon.
To make sure, please verify that it works well on Firefox browser.
Hi @ToanLS,
Issue #1 solved, thanks again.
Issue #2 I confirm in Firefox not happens the error, but in Chrome and Safari there is the issue and considering Chromium based browsers are used from most people, it will be very useful if you fix very soon this issue.
We will wait your update, please notify us when fixed and what we do to fix this active presenter project.
Thanks
I’ll let you know when the issue #2 is fixed, hopefully at the end of this week.
We’ve just released ActivePresenter 8.3.0 that fixes this issue.
You can update your ActivePresenter from Help tab > Check Updates, or download this version from the download page.
Hi @ToanLS,
Very thanks! It fix the issue, but there is a problem after.
When a video is completed, if you click play button, the video go on…
Why?
