The video is looped so the actual timeline duration is not limited by the last slide duration and this issue occurs. It’s not a new issue in version 8.3.0. We’ll fix it in the next version.
In the meantime, you can place the playhead near the end of the last slide, split the video, delete its latter part, and make the first part show to the end of the slide to overcome this issue.
Please see the steps in this video:
(Please note the issue will not occur if your video doesn’t loop and video duration is shorter than slide duration)
You can drag the right edge of the slide bar in Timeline to change the slide duration.
Slide duration can also be changed from Transition toolbar tab, or Properties - Slide > First tab > General section.
Video loop can be change in Properties > First tab > Video section.
Hi @ToanLS,
considering I have set 1 point for each correct answer, what is the right option for the SCORM in order to pass the lesson?
(I have Moodle as LMS)
Hi @ToanLS,
Thanks for your reply.
I Will try with these 2 options and I Will notify You.
In any case and in this specific project, I must to add a report slide at the end of not?
Thanks, but if I don’t add the report slide at the end and if I set well the pass option, the lesson is considered passed for Moodle, right?
P.s. in this case, considering that the user must to answer correctly 4 questions, what Is the right pass option?
Yes, the passed/failed result is always sent to the LMS when the lesson is completed.
The pass codition for answering 4 question correctly (1 point / question) is Points gained not less than 4
My script doesn’t hide the total duration.
It looks like you accidentally turned it off in Player Settings.
Please make sure Total Duration checkbox (in Player Settings > Toolbar) is checked.
