Is it possible to zoom in/out manually when ‘screen recording’ please? Pete
ActivePresenter Version: Required. Free version
OS: Required. win 10
Unfortunately, it’s impossible to zoom in/ out when you are recording screen.
However, after you finish recording, you can use zoom-n-pan effect to zoom in on a particular part of the screen, then add another one to pan or zoom out.
For more information, you can take a look at this tutorial:
Yen
Very many thanks for your help. Just the job.
Pete
