When I try to record the screen in minecraft, it just records a brown screen. it worked when I first downloaded it and then stopped and just records the desktop screen perfectly, then when I switch to minecraft it is a brown screen with a mouse cursor moving on it. sometimes it is the mojang logo…it is kind of random. when minecraft is minimized it records the chrome browser fine. I don’t understand, hopefully this is a known issue, would love some guidance. Oh and I tried restoring all defaults in case I changed a setting, but no effect. Thanks
ActivePresenter doesn’t support recording OpenGL.
You can try enabling the windowed mode to see if it helps.
Yen
