My voice recording goes in and out on recording, then disappears.
Can you provide the following files so we can check:
- The recorded project file and its external data folder named in the form PROJECT_FILE_files if any.
- The log of ActivePresenter in the path %APPDATA%\ActivePresenter. (Just copy and paste that in the address bar of Windows Explorer and press Enter. The log file is ActivePresenter.log in the opening folder).
I have no idea what you are asking me to do. Please a phone number for help!!!
2016-10-11 08:07:35: ActivePresenter 5.0.0 (Release Build: 2014.12.24) started
OS: Windows 7 (build 7601, Service Pack 1), 64-bit edition. Version: 6.1 - 64 bit
CPU Count: 8
Computer Name: FMB-1634 (ad.fmbfire.org). Memory: 16,309 MB. Available: 13,028 MB. Memory Load: 20%
Disk Space: 767,469 MB (Free: 49,301 MB)
2016-10-11 08:07:38: Checking updates for ActivePresenter v5.0.0…
2016-10-11 08:07:38: New updates available: 6.0.2
2016-10-11 08:07:41: Downloading [http://atomi-hc4kspjrkqferfkc.stackpathdns.com/updates/ActivePresenter/v6/ActivePresenter_v6.0.2_update.zip] to [C:\Users\rkraus\AppData\Local\Temp\ActivePresenter_updater_tmp\ActivePresenter_v6.0.2_update.zip]…
2016-10-11 08:07:57: Extracting [C:\Users\rkraus\AppData\Local\Temp\ActivePresenter_updater_tmp\ActivePresenter_v6.0.2_update.zip] to [C:\Users\rkraus\AppData\Local\Temp\ActivePresenter_updater_tmp\setup]…
2016-10-11 08:08:00: Executing [C:\Users\rkraus\AppData\Local\Temp\ActivePresenter_updater_tmp\rlupdater.exe C:\Program Files (x86)\ATOMI\ActivePresenter\ActivePresenter.exe C:\Users\rkraus\AppData\Local\Temp\ActivePresenter_updater_tmp\setup\ActivePresenter_v6.0.2_update.exe]…
2016-10-11 08:08:00: Running updater…
2016-10-11 08:08:00: ActivePresenter 5.0.0 (Release Build: 2014.12.24) shutted down
2016-10-11 08:08:51: ActivePresenter 6.0.2 (Release Build: 2016.08.18) started
CPU Count: 8
Computer Name: FMB-1634 (ad.fmbfire.org). Memory: 16,309 MB. Available: 13,040 MB. Memory Load: 20%
Project Location: \file\users\rkraus\Documents\ActivePresenter
2016-10-11 08:08:57: ActivePresenter 6.0.2 (Release Build: 2016.08.18) shut down
2016-11-07 12:00:30: ActivePresenter 6.0.2 (Release Build: 2016.08.18) started
CPU Count: 8
Computer Name: FMB-1634 (ad.fmbfire.org). Memory: 16,309 MB. Available: 13,106 MB. Memory Load: 19%
Disk Space: 767,469 MB (Free: 210,513 MB)
2016-11-07 12:00:40: Checking updates for ActivePresenter v6.0.2…
2016-11-07 12:00:41: New updates available: 6.0.3
2016-11-07 12:01:04: flt sample format is not supported, s16 will be used
2016-11-07 12:01:04: Preparing to record audio from: Microphone (Logitech USB Headset). Channel: 1. Sample rate: 48000. Sample Format: 8
2016-11-07 12:01:04: Failed to open audio stream to record. Error: Invalid device. Retrying with default parameters
2016-11-07 12:01:04: Preparing to record audio from: Microphone (Logitech USB Headset). Channel: 1. Sample rate: 44100. Sample Format: 8
2016-11-07 12:03:06: Start capturing. Mode: Full motion. Method: 0. Capture Size: (1680, 1050)
2016-11-07 12:03:06: Video Codec: libopenh264. Expecting FPS: 30.00
2016-11-07 12:03:07: Video will be recorded to: \file\users\rkraus\Documents\ActivePresenter\Untitled_tempdir\video_20161107_12-03-07.mkv
2016-11-07 12:03:07: bgr24 pixel format is not supported, yuv420p will be used
2016-11-07 12:03:07: flt sample format is not supported, s16 will be used
2016-11-07 12:03:07: Audio will be recorded to: \file\users\rkraus\Documents\ActivePresenter\Untitled_tempdir\audio_20161107_12-03-07.wav
2016-11-07 12:03:07: Preparing to record audio from: Microphone (Logitech USB Headset). Channel: 1. Sample rate: 48000. Sample Format: 8
2016-11-07 12:03:07: Failed to open audio stream to record. Error: Invalid device. Retrying with default parameters
2016-11-07 12:03:07: Preparing to record audio from: Microphone (Logitech USB Headset). Channel: 1. Sample rate: 44100. Sample Format: 8
2016-11-07 12:03:07: Audio 2 will be recorded to: \file\users\rkraus\Documents\ActivePresenter\Untitled_tempdir\audio_20161107_12-03-07_1.wav
2016-11-07 12:03:07: Preparing to record audio from: Headphone (Realtek High Definition Audio). Channel: 2. Sample rate: 48000. Sample Format: 8
2016-11-07 12:03:24: Stop video recording. Frames recorded: 375. Dropped: 0. Duration: 12599. Actual FPS: 29.68
2016-11-07 12:03:24: Recorded video data size: 406 KB
2016-11-07 12:03:24: ProcessRecordedAudio: duration (ms) 12661.333000
2016-11-07 12:03:24: ProcessRecordedAudio: duration (ms) 12665.979000
2016-11-07 12:03:26: RLMedia: Estimating duration from bitrate, this may be inaccurate
2016-11-07 12:04:04: ActivePresenter 6.0.2 (Release Build: 2016.08.18) shut down
2016-11-07 12:04:17: ActivePresenter 6.0.2 (Release Build: 2016.08.18) started
CPU Count: 8
Computer Name: FMB-1634 (ad.fmbfire.org). Memory: 16,309 MB. Available: 13,067 MB. Memory Load: 19%
Disk Space: 767,469 MB (Free: 210,511 MB)
2016-11-07 12:04:41: flt sample format is not supported, s16 will be used
2016-11-07 12:04:41: Preparing to record audio from: Microphone (Logitech USB Headset). Channel: 1. Sample rate: 48000. Sample Format: 8
2016-11-07 12:04:41: Failed to open audio stream to record. Error: Invalid device. Retrying with default parameters
2016-11-07 12:04:41: Preparing to record audio from: Microphone (Logitech USB Headset). Channel: 1. Sample rate: 44100. Sample Format: 8
2016-11-07 12:04:48: Start capturing. Mode: Full motion. Method: 0. Capture Size: (1680, 1050)
2016-11-07 12:04:48: Video Codec: libopenh264. Expecting FPS: 30.00
2016-11-07 12:04:48: Video will be recorded to: \file\users\rkraus\Documents\ActivePresenter\Pin Number for Narcotics_tempdir\video_20161107_12-04-48.mkv
2016-11-07 12:04:48: bgr24 pixel format is not supported, yuv420p will be used
2016-11-07 12:04:48: flt sample format is not supported, s16 will be used
2016-11-07 12:04:48: Audio will be recorded to: \file\users\rkraus\Documents\ActivePresenter\Pin Number for Narcotics_tempdir\audio_20161107_12-04-48.wav
2016-11-07 12:04:48: Preparing to record audio from: Microphone (Logitech USB Headset). Channel: 1. Sample rate: 48000. Sample Format: 8
2016-11-07 12:04:48: Failed to open audio stream to record. Error: Invalid device. Retrying with default parameters
2016-11-07 12:04:48: Preparing to record audio from: Microphone (Logitech USB Headset). Channel: 1. Sample rate: 44100. Sample Format: 8
2016-11-07 12:04:49: flt sample format is not supported, s16 will be used
2016-11-07 12:04:49: Audio 2 will be recorded to: \file\users\rkraus\Documents\ActivePresenter\Pin Number for Narcotics_tempdir\audio_20161107_12-04-48_1.wav
2016-11-07 12:04:49: Preparing to record audio from: Headphone (Realtek High Definition Audio). Channel: 2. Sample rate: 48000. Sample Format: 8
2016-11-07 12:05:46: Stop video recording. Frames recorded: 1548. Dropped: 1. Duration: 53150. Actual FPS: 29.11
2016-11-07 12:05:46: RLMedia: 1 frames skipped
2016-11-07 12:06:55: flt sample format is not supported, s16 will be used
2016-11-07 12:06:55: Preparing to record audio from: Microphone (Logitech USB Headset). Channel: 1. Sample rate: 48000. Sample Format: 8
2016-11-07 12:06:55: Failed to open audio stream to record. Error: Invalid device. Retrying with default parameters
These log lines are from 2016!!!
We need the most recent lines which are usually around the end of log file.
