Hello, I want to add a 360 degree controllable virtual tour link installed on youtube or vimeo to my project. When I add it as a web object, it gives a warning that it refused to connect when I preview it. Is there any way to run this? Thanks. The link I want to add: 080129924 istanbul sultanahmet hagia sop - YouTube
Hi Emrah,
As you are using the Web Object, you need to use the embedded URL of YouTube/ Vimeo (Share > Embed) instead of the normal URL you are using.
The normal URL you are using is blocked by YouTube/ Vimeo as they do not allow embedding into a web object using iframe.
Or, an easier way is using the YouTube object in ActivePresenter to directly insert a YouTube video into your project:
Hope this clarifies.
BR,
Quynh Anh
