hi from cancun !!!
one question, i made a program to type text in a variable name “SAVETEXT” and i need to the variable save local in the device used, then when i open the program in another device, show again what i save in that variable and show again , modify and saved again .. how i made that routine .. tks
For your information, currently, ActivePresenter does not natively support syncing variables like “SAVETEXT” across multiple devices in the way you described.
Since variable data is stored within the project file itself, and is not designed to persist or synchronize across different installations automatically.
BR,
