Variable is not set at “On Correct” event of drag & drop interactive.
If created a variable “quest_2” with default value false.
Added an interactive drag & drop with action to set the variable on correct and on incorrect.
After pressing next to show the next slide I want to display the result.
The variable is always false. Whats wrong?
ActivePresenter Version: 8.07
OS: Mac
