Use values in mouse click interaction to achieve different actions
In a record interactive stimulation, I have a mouse click interaction. The corrects values of this interaction are left click OR double left click.
I want, when the person just uses a left click, it goes to a specific slide but if it uses a double left click, it goes to another specific slide.
I know it is possible to do that with a text entry, but I can’t find a way to do it with a mouse click interaction.
For context, the person has to select a picture file (.png). When you doubleclick, it selects itself and the window closes. If you left clic, you select the picture, and you have to clic on an open button.
ActivePresenter version: 9.1.2
OS: windows 10
Thanks for your time
The events - actions and conditions in this case should be:
Hope this helps.
