Update/reload footages in Resource Panel for video and images
Can we have a reload of footage like in after effects once you overwrote the file and you “update/reload feature” it in the resource tab it will update on the stage with the changes that have made on the newly loaded footage so I won’t load again and erase the old file to save time.
You can right-click the resource in Resources pane and select Update from Original Files to update the resource with the content of the original file.
However in the current version this feature only supports text files (such as svg, js, css…) and it sometimes can’t detect changes made to the original file.
We’ll try to support it for all types of resources in the future.
