I wonder if you can help me please?
I want to be able to produce a panel/box that slides in from the top automatically when a variable is TRUE. And, then slides back up when the variable is FALSE.
I can do it on the timeline, but think it will need to be in Javascript for it to be more dynamic. Please help!
Many thanks.
Ian!
You can use Variables and Object States feature to achieve that.
Please take a look at the sample project to know how to do that: Up Down Panel Box.approj (240 KB)
Thank you so much Yen. Your file has helped me understand a lot.Instead of using the change states feature, I am using the timeline animation as I need part of the panel to stay on the screen at all times. The Fly animation was taking the panel off screen totally.
Again many thanks for your help. I was stuck on this for ages!
Ian
