It’s very difficult to use unicode emoji’s because they render in the browser differently than how they render in AP. Is there any way to make them render consistently between the AP desktop editor and the browser?
Hello,
Could you share a sample project so that we can understand better?
You can send it here or through our email address support@atomisystems.com.
Best regards,
Thanks for sharing the file.
The current version of ActivePresenter doesn’t handle 4 bytes Unicode characters well, so the issue. There is no workaround for problem, unfortunately.
We will try to improve it in the future.
