Thanks for taking your time using ActivePresenter!
We’ll try to improve ActivePresenter feature in the future release so that you can adjust the UI font size (Q1) and resize an object around its center point (Q3).
About Q2, you can go to the slide Properties pane > Interactivity tab. All the objects’ events - actions will be shown in the Events-Actions section.
In addition, you can send your suggestion for us through support@atomisystems.com. We really appreciated that.
Hi @PhuongThuy_Le Phuo
I would like to know if this functionality has been added in ActivePresenter, because I would also have this need.
But in the settings I don’t see anything that can make me change the font size.
Thank you very much
Kind regards
