A Word export does not create a TOC, even though I selected in the options when exporting. I thought that the ‘Name’ of the slide would be the Contents line
Can you please share the screenshot of the Export To Word dialog so we can know your selected options?
So, you are using custom layout from the template. Please make sure that all the $SlideName tags are set as Heading 1 and try again.
Thankyou this has helped me with my TOC issue
Kind Regards
Bryan
