TOC Collapses on Project Entry
Good day, all;
Quick question: is there a way to set a project (in Player Settings) where the TOC is initially collapsed? Now it seems that a project launches with the TOC open and with the button enabled users can close it, but I’d prefer it the other way around - that it launches with the TOC closed and the button can open it, so users start with the widest view possible.
I thought I’d asked this before and got JavaScript for it but I must me mistaken as I can’t find it anywhere.
TIA!
What if you place this JavaScript snippet on load of your slide?
prez.variable("apSidebarVisible",false);
Hi samamara,
Greg’s suggestion is a helpful approach.
You can apply the same idea using an action instead of adding JavaScript. In the Project On Load event, add an Adjust Variable action to set apSidebarVisible = False:
This will collapse the Side Bar/TOC when the presentation starts. Users can still use the Side Bar button to open it whenever needed.
Thanks, Greg, for jumping in!
Excellent @Giang_BTL - this will certainly help! Thanks too @gregs for your help and support as always!
samamara
