Hi, I having issue on timeline triggers when I already insert the trigger on the timeline but it doesn’t play the timeline.
Your prompt response is highly appreciated!
Thanks
Thanks
Hi Kuansing, welcome to the community ![]()
Could you please describe the issue in more detail so we can better understand it?
It would be helpful if you could provide a short video demonstrating the problem, or share some screenshots of your trigger settings and timeline.
You can also send the project file to support@atomisystems.com if possible so we can investigate the issue further.
Hi. I’m trying to play the LOOP animation (on LOOP timeline) (Pic 2) on REVEAL timeline.
I did insert the action to start the LOOP animation but it doesn’t work. (Pic 1)
And it also can’t start/play the animation at own timeline even there’s a timeline triggers. (Pic 3)
It seems you’re previewing inside the editor. Timeline triggers do not run there.
Please use Preview in Browser (HTML5 output) (press F5 by default) to test, as triggers only work there.
