The sound turns off when switching between slides
The audio file I added to the project section stops when I go forward or backward on the slatyt. how do I prevent this, I want the sound to always play
Would it help in your scenario to set your audio file as background music?
when I put the sound file in the background, the sound cuts out when I do the back and forth on the bottom bar. How do I prevent this
It seems there’s no way to achieve your desired outcome. When you navigate back and forth between slides, the slides reload from the beginning, and so does the audio file.
