Text Caption - Audio (text2speech) - Text disappears at end of narration
Problem: Text Caption - Audio (text2speech)
Hello, I am having issues with Text Caption when it has audio source attached to it. we have used the Text to speech feature to generate the audio and then selected it as the source in the text caption audio properties.
The issue is when the audio finishes playing, the text caption on the slide will disappear. for context, we are using this on a question slide.
I have tried using “Show to the end of the slide” option in the size and properties, but this forces the timeline to collapse and the audio no longer plays at the start of the slide.
I also don’t want to just drag the timeline out to several minutes either just to create a false timeline. Is there a proper way to use the audio source in the Text caption properties without the text disappearing?
ActivePresenter version: ActivePresenter Pro Edition - Version 10.6.1 - 64-bit. (Released: 2026.09.22)
OS: Windows 11
Hi Thien,
We tested this behavior, and the text caption remains visible after the audio finishes.
Please check if the Playhead is at the end of the text caption on the Timeline. If so, the text caption will not appear after previewing. Please move or remove the Playhead and try again.
If the issue still occurs, please send us a short video showing the Timeline and the issue.
Regarding Show to the end of the slide, when this option is enabled, the text caption follows the slide duration, so its duration on the Timeline may become shorter.
Best regards,
Giang
Hi Giang,
Thank-you for your assistance. I tried your suggestions out but same result. The issue is in the actual course when previewed. I have attached a video of the issue here and the settings in the editor.
Best,
Thien
Hi Thien,
Thank you for sending the video.
  1. According to your video, the Slide duration is shorter than the Text Caption’s duration, so an Exit animation appears at the end of the Text Caption on the timeline. When playback reaches that point, the caption disappears.
  2. When you enable Show to the End of Slide, the caption will only remain visible until the end of the Slide duration. Therefore, if the Slide duration is shorter than the Text Caption’s duration, the caption will be shortened.
Please follow these steps to resolve the issue:
  1. Set the Slide duration to match the Text Caption’s duration.
  2. Enable Show to the End of Slide for the Text Caption.
The Exit animation will then be removed. When you preview, the Text Caption will remain visible until you move to the next slide.
Best regards,
Giang
Thank-you for the quick support, Giang.
That has resolved the issue.
Thien
