Problem: bullet point text boxes seem to change when exporting to html5 - meaning that slide layouts change and elements no longer align.
ActivePresenter version: 8.2.1
OS: Windows 10
Notes: It may not be the font size - it may be the bullet indent size, but something changes the number of words per line. The problem is not apparent if you remove the bullets.
Very easy to recreate - create a blank slide with a text caption box in one quadrant. Enter several lines of text in the box - e.g. 4 sentences, each stating on a new line and each of which is than one line long. Copy the text box to another quadrant of the slide and indent the 2nd and 3rd sentences. Now, copy and paste the text box again and this time add bullet points on each line and also indent sentences 2 and 3. Now export as html5 and view the result. The boxes without bullets display the same as in the editor - but the box with the bullets does not.
