I have deselect the check box : Initially Expand Entries but the application continued to show the Table of Contents when start the video.
I have to make some other configuration?
Version 7.5.1
Version 7.5.1
Please set the Table of Content > Style option to None. You may also want to set the Side Bar > Position to None.
This configuration also makes the Side Bar Button disappear.
It is necessary to have the “Tablet of contents” activated through the “Side Bar Button”, as in the previous version.
Kind Regards,
You can leave the Side Bar and ToC options as default, and add the following script to ActivePresenter > Project > Properties > Event to hide the side bar at the beginning:
prez.showSidebar(false);
