Tables and Graphs
Maybe I missed it, but is there a way to insert tables and graphs? It’s getting a bit tedious to make them from scratch.
Active Presenter 7.5.8
Thanks
Hi Roxie,
Unfortunately, it’s impossible for you to insert tables and graphs in ActivePresenter directly. However, ActivePresenter supports you in importing files from PowerPoint. So you can add and customize tables and graphs in PowerPoint, then import this file to ActivePresenter.
Hope that helps.
