Could you tell me how I can change my subtitle? I don’t want it to show up with a highlight.
The other option doesn’t work for me. I’m not looking to just change the color.
Thanks!
Thanks!
Hi Laureen,
Thank you for your message.
This is a new feature for Closed Captions. It highlights the spoken words to help viewers follow the subtitle more easily.
If this style is not suitable for your project, you can turn it off by going to Properties > Style & Effects > Word Highlight, then uncheck Highlight Spoken Word.
Best regards,
Giang
