I have a drag and drop activity. When the user completes the activity correctly, the feedback layer “Correct” is displayed when clicking on the Submit button. However, when the user clicks on the submit button when they haven’t completed it correctly, nothing happens? Even though I have selected the relevant feedback layer for “Try Again”. Any ideas??
Hi there, thanks for your reply. The feedback master definitely includes all layers. Also, when I try to close the feedback master it sometimes will not close! I have to press the close master button up to 15 times before it takes me back to the slide view!?
Please also check again in the Events - Actions section (open the View tab > Slide Master > select the layout that you are using) to make sure you set it correctly.
Regarding this problem, please let us know the operating system you are using.
Does this issue happen with every project or just a specific one?
Can you please share the log of ActivePresenter (click ActivePresenter > Miscellaneous > View Log) and the project which has the issue so we can check?
If these files are large, you can upload them to a cloud storage site like Google Drive then email to support@atomisystems.com.
