Surprisingly, I didn’t find a way to make images or shapes clickable. I tried using the “Change state on click” events, but then I couldn’t reset the state to normal on the second click (multiple images choice).
In Articulate Storyline, the “selected” state is available by default, and there is also a “selected group” option. This allows you to create quizzes and games where you can choose a picture. How can you achieve this in Active Presenter?
When you want to make an object clickable - give this a try.
Select the object on screen and go to the properties panel for that object.
Select the Star icon as shown
Locate your object under the Events - Actions section
Click the plus icon to the right side of your object name
Choose On Click
There are multiple ways to change the states of an image or shape object in ActivePresenter such as using True/False variables, show/hide objects, or Number variables.
Please take a look at the sample project below for more information about the 3 cases of changing states:
Slide 1: Show/Hide Objects
Slide 2: Use the True/False variable to change object states
