Hello, I’d like to know if there is any mechanism to load resources while already having started a timeline. E.g. would it be possible to have a scene being preloaded and already being played while another scene is still loading?
Or is there any other way to start an animation before the preloader finished?
Yes. If you change the preloader from default to custom in the document panel and select edit, you can create a custom animation that occurs while the resources are being preloaded.
You can start the main document before the preloader finished by using the following script in a custom preloader event:
function eventInCustomPreloader(doc, e) { /* e.g. Item Complete event */
// make sure the loading document (the main document) is ready
this.loadingDoc.ready(function() {
// hide the preloader document
this.preloader.loaderDoc.show(false);
// start the main document
this.start();
@mackavi: creating animation directly in the custom preloader is a nice workaround.
Our goal is to NOT show the preloader and for the page to load as quickly as possible, allowing early elements to load sooner and the rest in the background.
Anything else I can do to for quick page loading with early events loading first and later events load later – like “lazy loading” (https://en.wikipedia.org/wiki/Lazy_loading)?
Start event occurs when the preloader starts loading the first resource.
If you want to start the main document after loading some resources, you can use Progress event.
For example:
// start the main document after loading 30%
function onLoadingProgress(doc, e) {
if (this.getProgress() < 0.3) // getProgress() returns value from 0 to 1
return;
// make sure to start the main document once
if (this.mainDocStarted)
return;
this.mainDocStarted = true;
this.start();
Please be noted that Saola Animate preloads resources in the order they are imported into Resources pane, so you should import resources used in the first scene first.
So, to load the main doc when 30% of resources are loaded, you add this code to the PreLoader / Event Handler / Start … Is this correct? Or is it Item Complete (I’m not sure).
You should add this code to Progress event as I mentioned. Start event only occurs once when the preloader start loading.
If you want the main document to start immediately, you can change the progress from 0.3 to 0.
Another method is adding the code in my first answer to Start event.
