Problem: is it possible to import an Excel spreadsheet into an Active Presenter?
Alternatively, is it possible to create a spreadsheet (with cells including mathematical formulas) in Active Presenter?
Hi Gilles,
ActivePresenter does not support importing Excel spreadsheets.
Also, with an ActivePresenter project, you can choose the option to export it to Microsoft Excel.
Slides will be converted into text, images, as well as objects and inserted into an Excel file afterward.
As a result, those objects are editable. Please read the tutorial below for more information:
However, with the cells including mathematical formulas like you request, unfortunately, we do not support them.
BR,
Quynh Anh
