I would love to see an implementation of the PowerPoint Slide Zoom function, where the transition between slides is effectively zooming in to a specific object on the slide.
I can workaround this by doing a zoom pan, but the aspect ration of the zoom and pan is fixed which limits the extent to which you can pick out specific objects that may not be the same as the screen ratio.
Thank you for your request.
Could you provide us with more detail about what you want to achieve so we can understand it better. (an illustration video is appreciated).
I’ve managed to make a workaround using slide transitions and the zoom/pan feature. I am still learning, but can live with this work around. It just needs me to size my objects to make it look right.
