Slide size for Instagram lacks
I miss the preset slide size for Instagram 1080 x 1920. Of course, I may insert it every time I need it, but … it should be in the dropdown list.
Hi Hans,
You can add your 1080 x 1920 size to your preset size list by selecting the Customize… option at the bottom of the recording size drop-down list.
Then, name your preset size, define its Width and Height, and add it to the list.
Hope that it helps.
BR,
