I would like to see the slide description box set up like the ‘notes’ window in powerpoint, large editor underneath the slide.
When you are narrating, you are reading the narration found in the description. You have to cut and paste it into notepad, then open both windows, then activate activepreseneter THEN do the narration. If the description window was bigger and underneath the slides like ‘notes’ in powerpoint, this would be so much easier to accomplish.
