"Slide delete" make ActivePresenter crash repeatedly
Problem: One of the slides in my project cannot be deleted or cut without having the software instantly crash. I want to get rid of this slide.
You should be able to access the project file here : https://filesender.renater.fr/?s=download&token=875e267b-3dcc-4f9e-9053-59e26828d860
The said slide is slide 21 (blank slide)
ActivePresenter version: 9
OS: Windows
Hi Marco,
Thank you for your reporting. Our development team is already working on a fix for it in the next updates.
BR,
Hi Marco,
It seems that the issue comes from the wordGameScore variable.
At this time, you can use the following suggestions as a workaround:
  • Delete the wordGameScore variable.
  • Delete slide 21
  • Re-add that variable to your project.
Hope it helps.
BR,
Thanks, it worked as soon as i deleted the variable and created new one, just as you said.
Solved! thanks a lot!
Hi @Marco_Buisson
We’re glad to let you know that the issue you reported has been fixed in ActivePresenter 10.1.
Please update to the latest version to enjoy the improvements.
BR,
