Issue:
I’m loving ActivePresenter so far. I’m just running into a snag when making a quiz. After submitting every answer in the quiz I get a feedback dialogue box where you have to click an extra button before moving on to the next question. I’d rather that the quiz went directly to the next question when the user clicks the submit button. Is there a way to do that?
Thank you for your nice words.
As you can see, a feedback layer appears after you submit a question. That’s because of the default events - actions are set up in the ActivePresenter questions.
But if you don’t want to click on the button in the feedback layer, you can change the questions’ settings.
In other words, to achieve your desire, just customize the events - actions of ActivePresenter questions.
I would like to instruct you the quickest way to do that then you can save the settings and reuse across projects.
Here are the steps:
Select the answer area > navigate to the Properties pane > Interactivity tab > Events - Actions section > Customize the default events - actions as you want > Close Master View. (Work with Events - Actions in ActivePresenter 8 - Atomi Systems, Inc.)
Please take a look at the screenshot below as an example. By doing that, after submitting a question, you will directly advance to the next question slide whether your answer is right or wrong.
