Hello,
I’d like to create a single click zone, for which two types of click are correct (single and double). But each click will trigger a different action.
So, the “correct” single click will go to slide 1 and the correct double click will go to slide 2.
Accepted values should be: left click and double left click.
But I’m stumped on which events/actions to set up.
Do you have ideas ?
Active Presenter 9.3.0 - windows.
Thanks for your answer.
Lucie
