Problem: How do I integrate a simulation into a regular project? When I record a simulation it saves as a separate project file, but if I want a simulation activity during a regular project I’m not sure how to integrate it in the middle of my project.
To integrate a simulation into a regular project, you simply select the slide where you wish to add the simulation in that project, then navigate to the Home tab > Record Screen > Record Interactive Simulation.
If you choose to access Record Interactive Simulation from the Start Page or the ActivePresenter button, it will create a new project. In this case, you should copy all the slides from the new project and paste them into the regular project to integrate the two projects together.
