Significant Memory Leak on macOS (M1) - Memory usage exceeds 8GB
Problem: Significant Memory Leak / Excessive Memory Usage (reaching more than 8GB) during editing tasks
ActivePresenter version: 10.1.1
OS: macOS 26.4
Notes: I am using a MacBook Air M1 with 8GB of RAM. I’ve noticed that the memory usage increases consistently the longer I use the application, even though I am not performing any screen recording.
According to the Activity Monitor, the usage reached more than 8GB, which exceeds my physical RAM and causes high “Memory Pressure” and heavy “Swap” usage. This happens during standard editing of slides and media assets. The memory does not seem to be released back to the system until I completely quit the application.
Attached is a screenshot of the Activity Monitor showing the high memory consumption.
Hi Hisbulloh Als Mustofa,
Thank you for your detailed report.
We were able to reproduce the issue on our side. This is a known issue that may occur during editing, especially when working with certain features and media in the project.
Our development team is continuously working on improving memory usage and optimizing performance in upcoming updates.
Thank you for your understanding. We’ll keep you updated on any progress.
Thank you for the confirmation and for reproducing the issue.
I would like to emphasize that this issue is currently a major blocker for my workflow. Since my MacBook Air M1 only has 8GB of RAM, a memory usage of up to 16gb forces the system into heavy “Swap” usage. This not only makes the application sluggish but also raises concerns about the long-term health of my SSD due to excessive write cycles.
Given the severity of this impact on my daily productivity, could you please provide an estimated timeline for when a performance fix might released? or a temporary workaround (other than restarting the app)?
I really appreciate your team’s effort in resolving this and i like this apps a lot. I look forward to hearing from you soon.
Thank you for your detailed feedback. We understand the impact this issue has on your workflow and appreciate your patience.
To help us investigate further, could you please share your project with us? You can attach it here or send it to our support email support@atomisystems.com. This will allow our team to analyze the issue more accurately and ensure upcoming fixes address your case.
Thank you for your support. We look forward to your reply.
I’m experiencing a very similar issue on my side.
On my Mac Studio, both RAM and CPU usage are extremely high when using ActivePresenter Pro Edition. I monitored it with Activity Monitor, and even when I’m not doing anything, the application consumes most of my 32 GB of RAM. CPU usage is also unexpectedly high.
As soon as I start using the program, the entire system becomes noticeably slow and unresponsive.
System details:
macOS 26.1 (25B78)
ActivePresenter Pro Edition 10.1.1 (64-bit, released 2026.01.30)
I’ve attached a screenshot showing the current resource usage. It looks like there may be a serious memory leak or background processing issue.
Hi Alice,
Thank you for your report.
We have addressed this issue in our recent improvements. To ensure that it is fully resolved in your specific case, could you please share your project with us?
You can attach it here or send it to our support email support@atomisystems.com. This will help us verify the fix and check if any further adjustments are needed.
Hello,
I have shared my simple project file along with a screen recording video related to the issue.
Thank you.
Hi Alice,
Thank you for sharing your project and the recording.
It appears that the issue has been resolved with our recent improvements.
The fix will be included in an upcoming update, which will be available soon. We will let you know once it is released so you can verify it on your end.
Hi Hisbulloh Als Mustofa and Alice Henneberg,
We have prepared a fix for this issue, and it has now been officially released. Therefore, the test build link has been removed.
We appreciate your support and look forward to your feedback.
Hello,
Thank you. I tested it just now. The high RAM usage issue I mentioned earlier has been resolved. It’s currently running stable, and the RAM usage is consistent.
Hi Alice,
Thank you for testing and for your feedback.
We’re glad to hear that the issue has been resolved and that the application is now running more stably on your side.
Your feedback is very helpful to us. Please feel free to reach out if you encounter any other issues.
Hi All,
We’re happy to inform you that the fix for this issue has now been officially released in ActivePresenter 10.1.2.
Please update to the latest version and let us know if everything works as expected on your end.
Thank you for your support!
