Side by Side Installations
Can ActivePresenter 10 be installed alongside AP 9 on the same Windows computer without modifying or replacing the existing version 9 installation? (Might take advantage of the Black Friday sale, but want to try 10 out first!)
Hi Chante,
You can run ActivePresenter 9 and 10 on the same Windows PC by copying the ActivePresenter 9 installation folder to a separate location before installing version 10. After installing version 10, launch version 9 directly from the copied folder. You may see a template loading message at startup. You can ignore it.
Before installing version 10, please close ActivePresenter and back up the shared folders so you can restore your settings and templates if needed.
If you open a version 9 project in version 10, use Save As to save it as a new file. Projects saved in version 10 can’t be opened in version 9, so keep the original file for use in version 9.
You can download ActivePresenter 10 and try most features in the Free edition. Our Black Friday sale only lasts one week, so give it a try soon to see if it’s a good fit and take advantage of the upgrade discount before the offer ends.
Best regards,
Hoa
Great, thank you. Such fast answers. I’m always impressed.
Just to clarify, the shared folders to back up before installing ActivePresenter 10 are:
  • %APPDATA%\ActivePresenter
  • The ActivePresenter Templates folder in your Documents folder
Please close ActivePresenter before backing up these folders.
