Showing/hiding with effect JS
Problem: Please see the uploaded project for the problem. Thanks.
ActivePresenter version: 10.1.1
OS: Win 11
showing-hiding object.approj (1.1 MB)
How about something like this…?
I just disabled the text box and re-enabled it after a timeout of the same length the you ran the animation.
Also added a variable for a quick conditional check
showing-hiding object-modified.approj (1.1 MB)
Exellent, Greg, thank you.
I also added a mouse-event so that the user does not have to enter the square again to make the circle disappear.
I get your solution with the variable. Shouldn’t it be possible to do the same with accessing the scale of the circle object?
Best, Rolf
showing-hiding object-modified_2.approj (1.1 MB)
