Show Media Controls Video and Audio at the same time
Problem: Hello,
I have recorded a video and it created audio and video as separately objects. I have enabled the Show Media Controls option at the video but I have a problem with the audio. For example when the user pauses the video, the audio keeps playing. I’m new here, can you please help me?
Thanks
ActivePresenter version: 9.1.5
OS: Windows 11
When you pause the video, the audio keeps playing because these recorded files are separate objects, @Fotini
But you can use the suggestions below to pause your video and audio simultaneously:
  1. Deselect the Show Media Controls option
  2. Use the Pause/Play button on the Player Toolbar in HTML5. This is the most convenient way.
    OR you can create a variable, then add events-actions to control your presentation.
    For newbies, we recommend you directly click on the button on the toolbar to pause your video and audio. If you want to use the variable, we’ll guide you later.
BR,
Many thanks,
To create a new project with this single slide and then export it as video so I can import it later to my main project, was the best solution for me.
