When you open the Music File show media control feature, the play and pause buttons appear in English, but the volume down and up buttons appear in Turkish. The language of the activepresenter is Turkish. Images are attached. Thank you.
Please share a sample project to support@atomisystems.com so that we can investigate further.
I sent an email with more details
Hi @emrahdirek,
Thank you for reporting the issue with us.
It seems like a bug and we’ll investigate further to find the cause of it.
In the meantime, please add the following script to the project’s On Load event (ActivePresenter > Project > Properties > navigate to the Interactivity tab), and adjust the last 2 lines of code to change the Play/Pause text to your preferred language.
Here is a sample project for your reference.
Untitled4.approj (684 KB)
No code has been added to the on load event in this project.
It’s been added to the project’s On Load event. Please follow the instructions above to find it.
Thank you very much, I got the codes
I made the adjustments you said and it works correctly. @Hang
Are you going to integrate it into the software? Or will I continue with the javascript code? @Hang
We’re working on a fix for this issue and will integrate it into the next updates. Adding JavaScript is just a workaround for now.
